Previous in Forum: Grease Specification   Next in Forum: LAT in Generator Set
11 comments
Water Hammer
07/20/2011 2:47 AM
dear friends ?
how do you do ? this is my question
what is the water hammer ? how to protect my Golf landscape ... ( the dimensions will be installed if you will ask about it ?) known that i have relief valve for the main pump and check valve to every pipe which suck from tanks ?
dimensions of pipes ( 12" , 10" , 8" , 6" , 4" and 3" )
the longest distance 400 meter ( between pump and last hole which will irrigate )
does the system need accumulator ?
Re: Water Hammer
07/20/2011 3:57 AM
water hammer is usually due to air trapped in the l water lines. there are different ways to prevent it depending on the design.
Re: Water Hammer
07/20/2011 4:52 AM
May you give me some suggestions ? about it specially i had relief valve on discharge line and 2 check valves (before and after gate valves ) of suction line ( cause my tank contains has 3 sub-tanks ) ???
Re: Water Hammer
07/20/2011 5:31 AM
i would install a cold water storage tank that has a air bladder inline with the water system. it should absorb the water hammer.
Re: Water Hammer
07/20/2011 7:58 AM
it means you will use hydro-pneumatic system for that ? or only just a tank which has half of water and there is a check valve its direction will be to tank ???
Re: Water Hammer
07/21/2011 2:13 AM
yes, i'm referring to a hydo-pneumatic tank. it should be placed near the source of the noise.
Good Answers: 266
Re: Water Hammer
07/20/2011 1:35 PM
What's the head pressure at the check valves. What you hear could be them slamming closed.
Re: Water Hammer
07/21/2011 5:37 AM
head equal Max. 12 bar
Good Answers: 266
Re: Water Hammer
07/21/2011 7:35 AM
what type of check valve did you use?
Re: Water Hammer
07/21/2011 7:55 AM
BIMEX
Double flanged swing check valve
PN 16 ,,, DN 150
Body : GGG50 ,,,, Gate : GGG50
Spindle : stainless steel
coating : Epoxy 250 microns
Good Answers: 266
Re: Water Hammer
07/21/2011 4:34 PM
The swing gate will slam shut with a lot of back pressure it could well be the noise you are hearing. 12 bar a lot of pressure. Use stethoscope to listen to them to see if they are the cause. If they are there are other types that will eliminate the slamming closed of the valve.
Re: Water Hammer
07/23/2011 9:13 AM
thank you
Register to Reply 11 comments
jlstitt (3); ozzb (3); stylee_eng (5)
