Previous in Forum: White fume for gas turbine cooling tower   Next in Forum: Water Hammer
Grease Specification
07/20/2011 2:01 AM
Hello all ....i have multi satage boiler feed water pump. Make KSB there is a tooth gear coupling spacer type please advise me which grad grease are require for coupling. Pump rpm is 2980.
Re: Grease specification
07/20/2011 4:36 AM
The grade will be in the Operation and Maintenance Manual supplied with the pump.
Good Answers: 25
Re: Grease Specification
07/21/2011 7:48 AM
Gear coupling does not have moving gears, it just transmits the power, I feel medium viscocity grease may be ok to prevent rusting. But please refer to manual, if you do not have same then you can approach KSB Pumps Ltd,Pimpri Pune,India. They can be searched on Google also.
Register to Reply 2 comments
