Previous in Forum: Deration Factor   Next in Forum: Are TEMA Requirements Applicable to WHRU Design?
ASTM SA516 Gr. 60N
07/21/2011 4:09 AM
Anyone could give me a clear difference between ASTM SA516 GR. 60N & ASTM SA516 GR. 60MT?
THANK YOU
Pathfinder Tags: ASTM SA516 GR 60N
Good Answers: 34
Re: astm sa516 gr. 60n
07/21/2011 6:25 AM
ASTM SA-20/A20M
MT:
Plates that are required to be heat treated,
and have been so heat treated, shall be marked by the
party that performed the heat treatment with the letters
"MT" (denoting material treated) following the required
ASTM designation mark.
NOTE 1 - Any stress relief of test specimens intended to simulate
post-weld heat treatment is not included in the above heat treatment.
N: Normalizated.
07/21/2011 7:06 AM
thank you whitephone..........
Re: ASTM SA516 Gr. 60N
07/22/2011 1:37 AM
Code SA516 /516M do not covers general requirement. For general requirement of plate you have to consult SA20/20M in which under clause no 13, plate identification is covered: For ready ref. part is as below:
13. Identification of Plates
13.1 Except as specified in 13.2, the name or brand
of the manufacturer, heat and slab number, and specification
number and grade, class and type, where indicated
in the material specification, shall be legibly steel die
stamped unless stenciling is specified by the purchaser
on each finished plate in two places not less than 12
in. [300 mm] from the edges. The year-date of the
specification to which the material is furnished need
not be included in the marking. For plates produced
from coils, the processor's identity shall be used rather
than the identity of the manufacturer. Plates, the maximum
lengthwise and crosswise dimensions of which
do not exceed 72 in. [1800 mm], shall have the marking
stamped in one place approximately midway between
the center and an edge. The manufacturer's or processor's
test identification number shall be legibly stamped
on each test specimen.
13.1.1 Bar coding is acceptable as a supplementary
identification method. Bar coding should be consistent
with the Automotive Industry Action Group (AIAG)
standard prepared by the Primary Metals Subcommittee
of the AIAG Bar Code Project Team.
13.2 For plates under 1⁄4 in. [6 mm] in thickness,
the marking specified in 13.1 shall be legibly stenciled
instead of stamped.
13.3 Plates that are required to be heat treated, but
have not been so heat treated, shall be marked by
the manufacturer with the letter "G" (denoting green)
following the specification designation mark required
by 13.1. Such plates shall have been qualified for
shipment on the basis of test specimens that have been
so heat treated. "G" marking is not required for such
plates that are for shipment, for the purpose of obtaining
the required heat treatment, to a processor under the
manufacturer's control.
post-weld heat treatment is not included in the above required heat
treatment.
13.4 Plates that are required to be heat treated, and
have been so heat treated, shall be marked by the party
that performed the heat treatment with the letters "MT"
(denoting material treated) following the specification
designation mark required by 13.1.
This shall clear the difference.
Register to Reply 3 comments
jojoedjan (1); Mukesh0861 (1); Whitephone (1)
