Thanks to all who can help!!!!
We are building a Water Pump Unit that will be capable of suppling water to a project, pressurizing that water, then recovering that same water to recycle for another project.
Ok, so here is what we have now. The engine is diesel powered at 130HP, it will have an engine adapter housing for the Hydraulic pump. The Triplex pump is a Tritan with the following specs: 10 GPM @ 500 RPM @ 85 HP. Lastly the Sliding Vane pump only needs 6 HP to operate properly.
So we have:
Engine: 130 HP (Supply)
Triplex: 10 GPM @ 500 RPM @ 85 HP (needed)
Sliding Vane: 6 HP (needed)
The triplex will need a hydraulic motor to operate it also. Its shaft size is 2 15/16" dia. 4 3/8" long and key way is 3/8" D x 3/4"W x 4"L
What size pump do we need, to mount onto the engine, to operate these pumps properly?
I know I will need a Hydraulic oil tank & cooler for this setup. Also the entire unit will be operated with joysticks inside of an operator shack.
Thanks so much for you expertise and knowledge in this project!!!
Michael
