Previous in Forum: Automatic Steam Trap Drain Point Location   Next in Forum: Metallurgy Question
16 comments
Maintaining the Tension on a Wire in Extreme Environment
07/25/2011 3:11 AM
I need to maintain the tension on a wire as it is heated in a dilute solution of NaOH from ~20C up to ~300C under ~1500PSI. The wire expands and I need some way to take up the slack from expansion. The solution to the problem must not react with the NaOH solution. It will also be exposed to elemental hydrogen and elemental Oxygen. Any ideas?
Working to end the use of carbon for energy
Good Answers: 266
Re: Maintaining the tension on a wire in extreme environment.
07/25/2011 7:27 AM
Easiest way would be to use a weight and pulley. Let the weight hold the tension as the wire expands and contracts it will move the weight up and down thru the pulley. With out some knowledge of the physical size of the tank, what the wire will do, is made of or how much tension on the wire is needed. I don't know if it will work.
If the wire is brittle and/or is to be electrified a insulator needs to be used. With more flexible wire ran thru the pulley to the weigh.
07/25/2011 9:05 AM
With information in the OP, this is a good answer.
I am sure we will get more info that makes this impractical... in the meantime, GA.
07/25/2011 4:02 PM
That is actually what I am working on now. Unfortunately the space / weight is limited.
Re: Maintaining the Tension on a Wire in Extreme Environment
07/25/2011 3:51 PM
Another way would be to form the wire into a coil (or zigzag pattern) and place it in the solution under tension. As the wire expands (and contracts) the coil will lose (and regain) some tension but should still have enough to stay in place, even under repeated or rapid thermal cycling.
This solution will obviously not work for all situations (especially if the wire is not flexible enough or too flexible) but may be a viable alternative as it requires no further mechanisms unlike those indicated in post #1 (which is the other good way).
07/25/2011 4:08 PM
Also a good idea that I have tried. I am using ZrOx ceramic for support and it does not have enough flex to take up the slack. I wish there was a material that could stand up to the operating conditions and had more flex to it.
If wishes were horses beggars would ride. And if it was easy someone else would have don it already.
Good Answers: 117
07/26/2011 8:26 AM
Good answer. That is what Edison used in his light bulb filiaments. (An extreme environment for sure!)
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
07/25/2011 4:04 PM
Use a wire that has a lower coefficient of thermal expansion that the structure that is supporting it or vice versa (note this will increase the tension on the wire as the whole thing is heated). For a constant tension, go for OzzyB's suggestion.
Sometimes my thoughts are in a degree of order so high even I don't get it...
07/26/2011 1:20 AM
The easiest way I see is to apply a spring on one end of the wire to compensate the elongation at the maximum temperature.
It would be good to know the purpose of the wire and material
  • what tension you require
  • what is the diameter and
  • length.
With this data you could calculate the thermal expansion.
A steel spring is not effected by caustic soda, hydrogen or oxygen. (I presume you are processing aluminium in the tank )
Good luck
07/26/2011 2:39 PM
Steal is readily attacked in dilute NaOH solution. The vessel is inconel 600 and every thing else is Ni 270, ZrOx or PTFE. I tried using some 625ss and rust forms on it. If you know of a spring or at least some what springy material that will function in dilute (0.1M - 1M) NaOH at 200C that would be great!
07/26/2011 1:21 AM
Maybe use pneumatic or hydraulic cylinder to maintain tension. Use spring at one or both end of the wire.
Pineapple
07/26/2011 1:21 AM
What about a temperature resistant silicon rubber tube or band that could be pretensioned to take up the slack?
07/26/2011 2:08 AM
How about a chunk of magnetic material holding one end of the wire, with a magnet outside the vessel to apply tension. Magnetic materials include ferrites, nickel, iron (this is a good chance), cobalt, magnetic alloys such as silicon steel (transformer steel).
If the vessel is magnetic, this may not work.
Good Answers: 117
07/26/2011 2:42 AM
Got to agree with Ozzb.. its the easiest and the most simple of arrangements, in fact if you look at any electrified train supply, that exactly what you will see for tensioning the wires..
07/26/2011 4:43 AM
glass towers with glass beads with holes in all of them to allow easy passage larger or more of the beads higher tension one more tower .. for more tension movement
easy calc for weight = tension
right glass non reactive in situation.. so a Pyrex possibly
Torque is not cheap
07/26/2011 9:03 AM
You did not mention how long the wire is, but would it be possible to connect one end of the wire to another wire which would be run over a pulley and then connected to a suspended weight? The weight would only need to be enough to maintain tension.
If this won't work, let me know and I'll try to come up with something better.
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
07/26/2011 2:59 PM
My avatar picture is the device in which this is taking place. The internal dimension is a cylinder ~4"D X 5"L. There is a basket, stir and heat exchanger inside as well as the wire. I am looking into #9. I did not think Silicon tubing would work at 200C but I hope it will. That would be an easy solution - the best kind.
Register to Reply 16 comments
angelo (1); Bob Morton (1); brich (1); ChaoticIntellect (1); Doorman (1); jack of all trades (1); merc600sec (1); ozzb (1); Phaddy (1); Pineapple (1); regsoft (4); robin.muir (1); Yusef1 (1)
