Previous in Forum: UTS Coordination of Tower, Conductor and Insulator   Next in Forum: Generator Terminal Output Voltage Regulation & Automatic P.F Control Problem
Lightning Arrestor Installation
07/25/2011 6:42 AM
Friends, Is it proper to link or loop the Ground pit for Lightning Arrestor to the electrical ground pit of a building through a conductor?
Re: lightning arrestor installation
07/25/2011 8:24 AM
What does the local code say?
Good Answers: 44
Re: Lightning Arrestor Installation
07/25/2011 2:03 PM
If it isn't connected to the same earthing source, then it doesn't really work as a lighting protection system, does it?
The building would be set at a different potential when a stroke of lightning hits, providing no protection to anything except the protection system!
As stated, the local code will tell you this.
07/25/2011 4:25 PM
NEC Article 250-86. This provision shall not prohibit the required bonding together of grounding electrodes(loop for building grounding & eletrode for lightning protection) of different systems which will limit potential differences between them and between their associated wiring systems.
B.E, M.I.E, M.S
Good Answers: 170
07/26/2011 10:26 AM
By all means! IS 2309 mandates that the Lightning Protection System must be connected (bonded) to the plant services earthing. Even IEEE 1100, IEC 60364 & the IEEE Green Book prescribe the same.
Register to Reply 4 comments
cuba_pete (1); electricalexpert65 (1); Mushtaq Hussainh (1); PWSlack (1)
