Previous in Forum: SAE Check Valve   Next in Forum: Air Enter Into System
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
Back EMF Test
07/27/2011 8:08 AM
Why back emf test is performed on any motors and in particular Brushless Permanent Magnet motors?
you need to go, to get something
Re: Back emf test
07/27/2011 8:21 AM
The early bird may get the worm, but the second mouse get's the cheese.
Re: Back emf test
07/29/2011 12:58 AM
Hello dcpppf,
Thanks for your reply.
But the links explains only what is back emf and i am clear about the concept. But my question is why back emf test is performed in motor testing?
Regards,
sharath
Re: Back emf test
07/29/2011 2:50 AM
If you truly do understand BEMF, then you should understand why it is part of testing. As with any other design factor, physical measurements are needed to verify calculated design values.
Re: Back emf test
07/29/2011 7:16 AM
The tests will be performed to verify the design values and practical values. I do agree. But what is the significance of back emf testing? Which parameters are verified? Just i am trying to understand to answer to my friend who is working in production line.
I think you are expert, please answer.
Re: Back emf test
07/29/2011 7:33 AM
Quality Assurance.
Re: Back emf test
07/29/2011 2:18 PM
The exact reason and method a particular production line uses a particular test is determined by their engineers.
A simple overview is here --http://dcacmotors.blogspot.com/2010/03/waveform-of-brushless-dc-motor.html
Re: Back emf test
07/30/2011 1:01 AM
Pantaz,
Thanks for your reply, the link explains back emf waveforms in a better way.
but i got the answer,
Back emf test is performed because the relationship between the back EMF and torque is so predictable.
Explaining:
KE= eLL / wm where 'KE' - back emf constant , eLL - peak line voltage & wm - speed in rad/sec
and eLL is approximately equal to Vs where Vs is supply voltage.
In similar way Torque constant 'KT' can be measured as
KT= T / I where T- Torque in Nm and I - DC supply current to the controller
in the ideal conditions with no saturation, no resistance and no voltage drops in the controller,
KT = KE
And Pelec= eLLI = VsI = Twm
Hence this test predicts torque output of the motor.
This explaination is with respect to 3 phase square wave brushless dc motors.
Register to Reply 7 comments
dcpppf (1); pantaz (2); PWSlack (1); sharath4 (3)
