Previous in Forum: Disposal of Battery Acid   Next in Forum: Banana Trunk and Corm Content
Conformal Coat Needed (CCT)
07/29/2011 7:36 AM
Does any one know of a Conformal Coat that meets or comes close to the following requirements
Here are the conformal requirements "wish list" :
The underlined ones are the current
Flexible/Soft
Low water absorption - 0.3%
Repairable
Secondary Heat Cure
High Dielectric Strength
Solder-ability-solder through conformal coat
Curable with both old (Mercury Vapor/Halogen bulbs) UV, and LED UV light sources
10 cc (preferred) - not a must
Durometer - A55 (similar)
Fast Cure time
Solvent Free
Bonds to Circuit boards, polyimide flex, metals, ceramic, glass filled Epoxy substrates
Clear
Viscosity - approx. 2,000 cP
Tensile Strength - 150 psi.
Elongation at Break - 30%
Storage:
Shelf Life of at least 1 year up to 90 deg F.
Thanks for your help
Re: Conformal Coat Needed (CCT)
07/29/2011 9:12 AM
This sounds like an acrylic, except for the flexible/soft part.
MIL-C-46058 used to be the MIL SPEC for conformal coatings. I don't know the current designation.
But I'd do what kramarat suggests.
Good Answers: 15
07/30/2011 12:35 AM
Take a look at HumiSeal 1B31 or 1 B31 LOC.
It is an acrylic, fairly inexpensive and pretty robust. My only question would be the water absorption - and that would apply to almost any acrylic. Your rework requirement mostly rules out urethane or silicone.
07/31/2011 7:39 PM
There is/was a mob in Australia called Senson, they have a conformal coating that should do the trick.
'Nunc est bibendum'
Register to Reply 3 comments
crashcol (1); lyn (1); osborne83 (1)
