Previous in Forum: Vernier With More Than 1 Memory Cell/Location   Next in Forum: Pressure Safety Valve
Optical Fibre Cable
08/02/2011 1:43 AM
I needed an OFC as per specas below
Type : ArmoredNumber of fibres : 24Number of loose tubes : 4Number of fibres per loose tube : 6 (Six)but supplier sent an OFC withType : ArmoredNumber of fibres : 24Number of loose tubes : 6Number of fibres per loose tube : 4
so what will be the effect in operation?Please tell me.
Pathfinder Tags: OFC
Re: Optical Fibre Cable
08/02/2011 10:49 AM
Well, there's nothing stopping you from going to the market and getting it.
Good Answers: 213
08/02/2011 10:50 PM
None. But you may have to modify your plans for connections.
08/03/2011 10:20 AM
Good Answers: 22
08/03/2011 10:52 PM
24 fibres is what determines how many connections you can make, so No, no difference.
However, as stated by CWarner7, it may affect how/where you connect to the fibres, as each of the 4 inner tubes will now have 6 fibres inside, instead of having 4 fibres in each of 6 separate tubes.
Optic Fibre Cables sort the fibres into tubes to assist with physical protection & ease of identification within the sheath/tube. Any fibre within the sheath can do the same job as another. See diagram (supplied for those of you who may not already be familiar with fibre layouts within an O/F cable)
Cheers
Tony
09/19/2011 9:55 PM
Why don't you try to ask a fiber optic cables expert with regards to this? Maybe they can help you out.
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Visit my blogs about fiber optic cables at http://fiberopticcables.posterous.com/
Anonymous Poster (1); cwarner7_11 (1); OldTechNewToys (1); ronron (1); user-deleted-1074 (1)
