Previous in Forum: STUB Bus Protection   Next in Forum: Duty of Circuit Breaker
Vacume in Steam Turbine
08/02/2011 8:46 AM
How the vecume of a steam turbine can be improved?
What are the constructional & operational causes of vacume drop of a Steam Turbine?
Re: Vacume in Steam Turbine
08/02/2011 8:52 AM
A2: leaks, from outside to inside.
A1: stop the leaks.
Good Answers: 67
08/03/2011 5:03 AM
Vacuum drop of a Steam Turbine may also occur if condenser is inefficient or cooling water temp. is high or water side tubes clogged/scaled.
