Previous in Forum: Tin Plating Over Aluminum   Next in Forum: PI Value of Synchronous Generator
12 comments
Air-Conditioning Unit
08/03/2011 11:09 AM
Hi,
We have 3 Air-conditioning unit installed in our plant and we need to know what spare parts you recommend to us to be have on hand.
And also the standard operation procedure for the preventive maintenance.
Find below the specification of the Air-conditioning
ACRAN APAC Heat Pump
Model P075AHR9AD
Conf Po75ARDo62917
Volt/Ph/Hz 415/3/50
FLA 65-82
Cap watts 75000
Refrig R22
Charge 7,5/Circuit
Serial No 063593
Serial No 063594
Serial No 063595
Thanks
Re: Air-conditioning unit
08/03/2011 11:25 AM
Contact the equipment manufacturer.
Why ask us to speculate?
Re: Air-Conditioning Unit
08/03/2011 11:36 AM
08/03/2011 11:44 AM
Assuming you ALWAYS have clean voltage and are performing routine maintenance...filters, cleaning BOTH coils, etc. I would say based on about 30 years experience the 1st thing to go will be the outdoor fan motor. This would be followed by the indoor fan motor. These are not certainties.
If you have voltage issues from time to time you'll be killing the entire machine with every hit it takes. Keep it clean and do your maintenance and a commercial machine will easily surpass it's 12 year design life. If your plant has a harsh environment like dust, acid fumes, etc. you'll never see the 12 years. That's just the cost to be comfortable.
08/03/2011 12:02 PM
Not to second guess you Fredski. But, I woke up this morning with no AC in my house...................it's going to be 102°F here today.................PANIC!!!!!
I just got done changing out the capacitor...............panic averted, all is fine. ($17 US) for a new one.
I think spare capacitors are a must have item on the list. They're inexpensive, and they like to self destruct. Apparently not only are they all manufactured somewhere else now, China, Mexico, etc., but since the pcb's in the oil have been banned due to cancer risks.................they tend to overheat.
08/03/2011 12:08 PM
When I began in the HVAC industry last century caps almost NEVER went bad. You touched on foreign born parts are getting worse all the time . Sad but true.
08/03/2011 12:33 PM
I wasted an hour checking other stuff in the air handler because I just changed the cap last summer. The previous one was in place and working since 1986.
It is depressing not being able to find stuff that just works anymore...................unless of course, you happen to be in the HVAC business.
08/03/2011 1:10 PM
"It is depressing not being able to find stuff that just works anymore"
That's the Microsoft product development mentality. Build it cheap, quick and dirty and let the customer sort it out.
The other one I love is something like, "do not return this product to the retail store where you bought it. Call our Help Line (where no one speaks or understand english) first".
08/03/2011 4:26 PM
It's gonna break my heart when that unit finally dies. 1986 Sears Kenmore 4 ton. I've changed the capacitor (twice), contacts and fan motor.........that's it.
I hear the life expectancy on a new unit is about 8-10 years.
08/04/2011 4:32 AM
Thank you for your valorous feedback.
We have this problem:
one compressor is over heating;
Problem of drier filter;
Aircond running not cooling good.
Please can also provide suggestions for the preventative maintenance.
08/04/2011 4:34 AM
08/04/2011 1:08 AM
If you have a nearby HVAC equipment and parts supplier, you may not need to keep any inventory of your own. Otherwise, some good spares to have on hand might be: capacitors, fan blades, filter/dryer cartridges, and fuses. Less likely, but still reasonable, would be motor contactors or parts, circuit breakers, refrigerant, and thermal expanson valve.
08/04/2011 4:31 AM
Register to Reply 12 comments
Anonymous Poster (1); Fredski (2); kramarat (3); lyn (2); Tornado (1); Walotech (3)
