Previous in Forum: Waterproofing   Next in Forum: Sound Proof Enclosure To Contain A 120Db Banshee
Inexpensive hot water.
08/04/2011 2:44 PM
Lay down a 4" thick square bed of asphalt, say 20'X20' in Texas or 30'X30' in Minnesota depending on amount of heating needed, with 1/2" copper flexible tubing in the middle. Tamp the last 2" lightly as possible and with great care.
Connect a water source to one end and say a swimming pool to the other end and "voila" your heat engine is ready to go to work.
If you get a lot of ice accumulation in your part of the country, you may want to think about temporarily covering this asphalt pad with a few inches of wood mulch prior to anticipated accumulations
Anonymous Poster #2
Re: Inexpensive hot water.
08/07/2011 10:16 AM
Brilliant! After tearing up 800-1,000 square feet of area, and investing $30,000USD on materials and construction you will have a swimming pool that will stay warm enough to use for an extra 5-30 days per season, depending where you are.
When can I get mine?
Reply Score 1 for Off Topic
08/08/2011 11:39 PM
This construction would not be on your employers dime, but rather a home made project. The pool was simply an EXAMPLE. You could use it to shower with. It won't provide you with any social skills though.
Good Answers: 44
08/12/2011 11:27 AM
I think in the winter you would either blow it out prior to "lay-up" and/or run heated water through it to keep the driveway clear.
Some Scandinavian countries heat their roads to keep them clear of snow and ice using geothermal power.
Anonymous Poster (1); cuba_pete (1); webpilot1 (1)
