Previous in Forum: Inexpensive hot water.   Next in Forum: Chimney Curing
16 comments
Sound Proof Enclosure To Contain A 120Db Banshee
08/05/2011 11:19 PM
I am spinning a blower, that would normally sit on a V8 engine, to the point where it is screaming at 120dB. It is currently running in a soundproof test cell, but I would like to run it in other environments. Do you have any advice on how I can dramatically reduce the sound?
To set the seen the blower is mounted to a steel table top and it is connected to an electric motor by a belt. I have the ability to build a box lid that would sit over both the motor and the blower and rest on top of the table. I don't have to worry about heat buildup that has been taken care of. I am looking for easy to find and low cost materials. I can fabricate the box lid on site. This doesn't have to look good, it just has to work.
The materials that came to mind were layers of: plywood, drywall, underfloor sound insulation, and maybe acoustic absorbtion foam. I could either find a self adhering rubber gasket to form the seal between the lid and the table, or I could use calk. Thank you for any advice.
Re: Sound proof enclosure to contain a 120dB banshee
08/06/2011 1:10 AM
Why not just keep the soundproof test cell around it?
There's a hole in the bucket, dear Liza....
Good Answers: 130
08/06/2011 5:33 AM
If it is making that much noise, it's inefficient. I.e. improve the efficiency and the noise problem self-solves.
Re: Sound Proof Enclosure To Contain A 120Db Banshee
08/06/2011 10:50 AM
Thanks for the comments, but all I am looking for is suggestions on how to build a sound reducing box around the device. I hope an accoustic engineer can provide some suggestions.
Good Answers: 130
08/06/2011 10:57 PM
There are dozens of off the shelf acoustic damping materials - starting at lead through to foam (of various flammabilities and degree of noxious)
What is not clear is what frequency range and what is making the noise.
For instance; is it vibration of the blower, drive, etc, 'drumming the steel table?
Is it purely intake noise? or output noise?
Second tier is what aspiration volume, if any, is required.
Third, what of heat due to compression, or friction?
Fourth, do you need to see the thing?
Answer those and perhaps an acoustic engineer would have a chance at making a useful suggestion.
For instance; if you levitate it in a perfect vacuum, I guarantee it will be totally silent.
Though how that 'enclosure solution' effects your testing, is possibly worth a small ponder.
08/06/2011 10:30 PM
First of all what size/type blower are you using and how fast are you spinning it? Too much noise is generated when there is something mechanically wrong with the blower, or the blower is spinning way beyond it's rated RPM. If the noise is coming from the drive system and not the blower you need to examine the alignment and tension on/of the driving system.
08/06/2011 10:47 PM
Record the noise and play it back through speakers aimed at the blower and and alter the pitch until you get wave cancellation. beware! you can easily find a harmonic and double the level.
08/07/2011 1:14 AM
Unless you want to try to duplicate some of the esoteric methods that are coming out of bleeding edge research your best bet is mass, the more the better. Clearly it has tradeoffs. Want to be able to see it? How about some nice 1" thick glass? How about bricks, they're cheap. You can put all the foam you want but it isn't going to be a substitute for mass.
Good Answers: 196
08/07/2011 2:20 AM
I think I'd start with a simple box constructed out of some cheap 2x2 vinyl coated steel wire fencing material. Stuff comes in rolls you buy at Home Depot or Loews. Cuts wit simple wire cutting pliers and fasten at the corners with twisted wire. Then go to Costco or Walmart and see if you can buy one of those visco-foam mattress toppers for material to line the outside of the wire mesh box (plan on using lots of duct tape).
If that material doesn't appeal to you try some 2" thick polyisocyuranate rigid insulation foam (foil coated preferably) that comes in 4x8 sheets at some professional lumber/building supply companies. (provide local building codes allow it). Cuts easy with any kind of saw; but try not to breath the dust. Fasten to the wire cage with tie wraps and duct tape. Isolate and seal the enclosure to the machine mounting base with same or similar foam.
This will tell you how much of the noise is being transmitted directly from the blower structure to the air. There are other paths to consider of course.
Canada - Member - New Member
Good Answers: 11
08/07/2011 6:28 AM
A baffle muffler?
Engineering Fields - Nuclear Engineering - New Member Engineering Fields - Power Engineering - New Member
Location: From going to and fro on the peninsula and walking up and down on it
Dealing with Banshee's as a bible school janitor
08/07/2011 7:01 AM
oderint dum metuant
Good Answers: 130
Re: Dealing with Banshee's as a bible school janitor
08/07/2011 9:54 AM
Good links; I liked this;
"A proposal to increase the aircraft's speed by adding afterburners was canceled after a test aircraft suffered extensive damage to the wing roots and tail structure when the afterburners were actuated"
found here
08/07/2011 11:25 AM
In my experience as an audio engineer for broadcast radio, multiple layers of differing mass material + random hard surfaces = less db transmitted through.
So. sound hits hard surface first and reflects randomly back into the device/room.Second, the energy that passed through the first layer must now move through a second layer that is soft and thick. Third layer is some where in between in thickness and softness and can include another hard layer like a layer of foil.
This differing of material and thickness forms a baffle of sorts but in a straight line from the source. Each transition causes loss because the best frequency to pass for each layer is different, but the sound you are absorbing is a constant set of frequencies. Lead foil in the center layer will drop the dbs quite a bit when surrounded by open-cell foam rubber and closed-cell foam rubber.
Same type of thing is done with radar absorbing layers.
08/08/2011 1:40 PM
Beefburger, Thanks this is the sort of practical advice I was looking for.
08/10/2011 9:22 PM
Can you tell us what the frequency is? Do you have an analyzer, or a Db meter?
Lead comes to mind, with the minuscule information provided.
08/14/2011 5:02 AM
if the the blower is adjusted correctly, the rotor noise should be drowned out by the velocity of the incoming air. i would'nt stand with in a 100' of it. instead of designing a sound proof enclosure, i would suggest wrapping it in a kevlsar blanket. the rotors have low tolerances and very few people have the experience to be able the adjust them correctly.
Good Answers: 59
08/14/2011 5:14 PM
The original question does not hang together. I used doing maintenance on my old V8 driven car, with the hood up, my head stuck under the hood. No problem, no screaming even when revving up.
If it is screaming for you, it is vibrating like crazy, from brutal overdrive. It will fail, soon. The fatigue cracks growing will let it blow up like small bomb. The fan is heavy gauge steel. An enclosure will not contain it, when it decides to fly. Not a healthy environment to be in.
What is the point? Exhaust and blower can be had off-the-shelf for a reasonable price, with engineering done right.
Register to Reply 16 comments
34point5 (3); AE (2); Anonymous Poster (1); Deefburger (1); Ed Weldon (1); Engineering Superman (1); gigaconcept.com (1); JIMRAT (1); leveles (1); lyn (1); packrat561 (1); rcapper (1); Tornado (1)
