Previous in Forum: What is the Posting Limit?   Next in Forum: What Happened?
Good Answers: 114
Line Spacing Bug
08/05/2011 11:31 AM
ever since chrome has gotten formal support on CR4
the line spacing when I reply to a PM is broken [composing is fine]
usually I write a sentence, hard return
which gives me a double space & new line
another instance is after dragging or pasting text, I'll pull some text from above as an example
  • Look for answers before you post. Search CR4 or use a search engine to see if you can find the answer to your question.
  • Provide as much information as possible. The more details you provide, the better the chance that someone on the site will be able to help you find an answer.
  • Give some thought to your post title. Don't use "Hello", "Question" or "Help". Also, simply saying "DC Motor" is not enough. Be specific, e.g., "How Do I Install Replacement Brushes In My DC Motor". Keep it professional - post titles should be written in title case
  • I can't turn off the bullets either
  • this all looks normal as I'm composing it
  • when I preview, the formatting will be broken for everything after the inserted text
Good Answers: 114
Re: line spacing bug
08/05/2011 11:35 AM
I'll drag some more to see if I can reproduce some of the other effects
I can turn off bold, because I set it
in the 1st post even highlighting the bulleted text won't let me turn them off
Good Answers: 114
08/05/2011 11:46 AM
to be clear I'm on Chromimum, which is the open source project, that provides most of the code for Chrome.
Good Answers: 114
08/05/2011 9:29 PM
another example
http://cr4.globalspec.com/thread/71056#newcomments
double spacing became single
the last line was 2 lines
"here" migrated to the line above
none of this stuff is a huge problem
just bugs
Good Answers: 114
08/06/2011 11:44 PM
Here's some screenshots that illustrate how it looks when I composing
you can see above how the spacing disappears & below after I added some of the spacing back
I figured this would bring some clarity
once again, just a bug report
not the end of the world
Register to Reply 4 comments
