Previous in Forum: Welding   Next in Forum: GOST Hydrotest Allowable Stress
11 comments
Stator Slots
08/09/2011 7:21 AM
I have come to known that induction motors are designed only with a standard set of slot numbers e.g. 24 slot ,36 slots , 48 slots stators and you will not find motors with any given number of stator slots. Do any one have any idea about it and can someone give me the standard values of slot numbers used in single phase / 3 phase motors.
Also can some one explain the relationship between stator slots and rotor bars /slots for a cage motor i.e. how much will be the rotor bars for a given number of stator slots.?
Re: Stator Slots
08/09/2011 10:30 AM
- Number of stator slots for three-phase , double-layer winding must be divisible by 3.
- Number of stator slots for three-phase , single-layer winding must be divisible by 6.
Single-phase winding can be done for all upper cases + some additional number of slots (16 or 32 for example).
Zlatkodo
page
Re: Stator Slots
08/09/2011 2:50 PM
tanx a lot. but i did not get the rule you provided for single phase motors slots.can you plz elaborate it a bit with example.
regards,
Re: Stator Slots
08/15/2011 5:28 PM
The stator slots must also be divible by the number of poles in the windings.
speed (rpm) = 60*60Hz/poles (less about 1% for induction slippage) (typical poles = 1, 2, 3, 4, 6)
Unless you are actually designing a new motor, you should not have to worry about any of this. Pick the size motor with the speed that you need!!
Re: Stator Slots
08/28/2019 12:26 AM
I am searching for some help that how I can play casino games because I want to be perfect in this and want to make money but I don't know so much about this.
Re: Stator Slots
03/30/2020 10:00 AM
Hi, I'm also looking for a reliable casino to play real money slots. Have you found any?
Re: Stator Slots
03/31/2020 11:34 AM
Have you tried to watch videos on YouTube with strategies?
Re: Stator Slots
08/28/2019 1:15 AM
Re: Stator Slots
08/28/2019 7:09 AM
CR4 Admin: Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the Site FAQ about advertising.
Re: Stator Slots
10/13/2019 10:13 AM
Re: Stator Slots
10/16/2019 3:38 AM
Re: Stator Slots
10/16/2019 3:39 AM
Good post
Register to Reply 11 comments
Anonymous Poster (1); coolyaar (1); Kilve1937 (1); Kristian (1); LarryDAdams (2); Randy9 (1); SolarEagle (1); TristanBrown (1); Valtor (1); Zlatkodo (1)
