Previous in Forum: Electric Motor Lifetime   Next in Forum: Stator Slots
Welding
08/09/2011 5:29 AM
i have to arc weld 1mm GI sheet on MS plate 2mm thickness. Pl advise, how and what size welding rod should be used
Re: welding
08/09/2011 6:14 AM
You'll need to use the smallest rod you can find on the lowest power setting you have.
Although I believe that you are doomed to failure after reading some of your previous posts, don't breathe the fumes if you try to do this.
I am constantly amazed amused bewildered by the questions asked here by posters such as yourself. Maybe that's just part of the entertainment value of this site.
Good Luck.
Re: Welding
08/09/2011 8:19 AM
Zinc fumes are very hazardous, and the welding will destroy the protection offered by the zinc coating in the region of any weld.
What about rivets, screws and nuts, or adhesives instead?
Re: Welding
08/09/2011 10:31 AM
You would be better off to MIG or TIG this material. It sounds as though you don't know enough about ARC welding (or any other type of welding) to attempt this project. Sorry to be so blunt but you are going to ruin your material if you try to do this work yourself.
CARPE CRUSTULORUM!
Register to Reply 3 comments
lyn (1); not so smart (1); PWSlack (1)
