Previous in Forum: INDUCTION MOTOR DATA   Next in Forum: VFD Size
Surge Protection/Lightning Protection for VFD's
08/09/2011 7:43 PM
A plant's electric load of VFD is +95%
Surge protection/lightning protection is required. These are 3 phase VFDs therefore +95% of the loads are three phase. The decision was made to make the system a 3 phase 3 wire based on this fact.
How can you utilize SPD/TVSS that work in this system voltage configuration?
The literature i have explored on SPD and TVSS from Square D point out that a solidly grounded system is a must to use this equipment. Is that true for all SPD/TVSS devices?
If there is no alternative but to make the system solidly grounded to accommodate for SPD/TVSS what are the pros and cons of making this change?
Re: Surge Protection/Lightning Protection for VFD's
08/09/2011 10:22 PM
Have you looked at total protection solutions? This data sheet shows 3 -wire Delta systems with ground. http://www.tpssurge.com/st-series/st400-tps.pdf
I assume you have a ground. You don't need a neutral leg just a solid ground.
The guys at Technicon can help you get the unit you need.
08/10/2011 12:03 PM
you are correct. There is a ground.
I will read your references.
thanks!
Good Answers: 117
08/10/2011 11:40 PM
Yes.. or it doesn't work!
Anonymous Poster (1); brich (1); wagado (1)
