Previous in Forum: Chemicals to Remove Paint from Pavement   Next in Forum: Impact of Degree of Vacuum on Vacuum Pump Capacity
Formic Acid
08/10/2011 7:05 AM
I am an engineer working on designing a device that generates Hydrogen from the formic Acid.
Can you help me in finding out what material can resiste the formic Acid?
Re: Formic Acid
08/10/2011 7:59 AM
Go to the Cole-Parmer on-line materials compatibility database and read all <other corrosion charts are available>. Any search engine will find it.
Re: Formic Acid
08/11/2011 1:41 AM
Wow, 2nd post today quoting the Cole Parmer database.
http://www.coleparmer.com/techinfo/chemcomp.asp
Re: Formic Acid
08/12/2011 4:18 AM
Check out tomorrow....
Good Answers: 48
Re: Formic Acid
08/10/2011 8:00 AM
There are a number of websites, like this one, which show chemical compatibility for a range of chemicals and materials. Google "chemical compatibility" and you will find many more. Always use at least two or three and crosscheck between them. This will give an indication, but not a guarantee, so always test the material yourself before you launch the product.
Re: Formic Acid
08/10/2011 11:40 AM
It is clear from your post that you have no experience with materials. Not sure what your area of competence is, but PLEASE READ THE HANDLING PRECAUTION NOTES on formic acid very carefully before this project begins.
Since you also seem not able to search for information, I have provided
Occupational Safety and Health Guideline for Formic Acid
this for you.
Re: Formic Acid
08/11/2011 3:34 AM
use the same material where the acidi is delivered.this iusally hd=high density polyethelene or polypropylene.
Register to Reply 6 comments
ajwinemaker (1); emil (1); Holzfeller (1); lyn (1); PWSlack (2)
