Previous in Forum: sell Chalk Making Machine0086-13939083462   Next in Forum: Can the cut section of the led strip be re-used?
Assembled LED Module String To Note
08/13/2011 1:51 AM
Assembled LED module string must pay attention to LED anode cathode is connected correctly
Monochrome LED module string assembly including the Monochrome LED module string Insert lamp and wiring.
Monochrome LED module string Insert lamp and wiring is very simple, clean the drilled hole and then insert the lamp
Insert the lamp into the corresponding hole
When Wiring, you can follow in order to connect, pay attention to all the LED module string of anode or cathode as far as possible together,it Can save the use of wiring cable while ensure connecting beautiful, all anode connect together, and then leads to the anode line, All the cathode wire connected together, and then leads to the cathode line
Re: Assembled LED Module String To Note
08/13/2011 7:03 AM
But I don't have/want LEDMODULE String so???
Do you send the O&M (operation and maintence) instructions on forums so that you cal tell later I have already informed you why didn't you follow?
I always thoufght that these are to be provided on neat english (of course other languages may too be there) typed on glossy paper and bound book.
Then of course the customers would find out and read and then they may put a litigation that despite following all the instruction in toto my laptop cell LED string exploded.
08/13/2011 7:47 AM
I wish this had been posted a few days ago.
Just the other day my wife and I were discussing LED modules and while I was wondering out loud how important it is to make sure the cathodes are connected together, she was telling me to be careful because I almost inserted the module into the wrong hole.
Good Answers: 130
08/14/2011 1:46 AM
Could be why one leg is longer than the other
Perhaps you should try it with her flat on one side?
08/13/2011 11:14 AM
This is just crass commercialism.
The spelling is OK but the sentence structure and syntax is just wrong. You should have had a translator correct it before publishing it here.
I wouldn't waste time on this product for fear that it is no better than the poorly worded commercial you just presented.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
08/14/2011 11:14 AM
Y'all got a question? Didn't think so.
Speak softly and carry a big stick.
34point5 (1); Anonymous Poster (1); lyn (1); standarded (1); Usbport (1)
