Previous in Forum: Defective Electronic Boards Causes Supply Fuses To Blow?   Next in Forum: Capacitors in Inverters?
Switchgears Preventive Maintenance
08/13/2011 3:10 PM
a main portion of the preventive maintenance of our switchgears is cleaning of dust , especially from the filters of cooling fans installed on our UPS inverter and charger modules. the staff cleans the dust with external blowers which blows the dust off in the air . i do not like this method of removal of dust because ,after all where does the dust go ? i think no where .it is just blown off in the air by the blower and then falls down on even more equipments and panels. now i want to know is there any way so that dust be sucked off the panels/components completely and not just blown in the air by blower.is there any sort of dust attracting vacuum cleaner etc ?
Re: switchgears preventive maintenance
08/13/2011 3:42 PM
Vaccum cleaners are available for this purpose. They are having dust bags in which the dust is collected.
Good Answers: 15
08/13/2011 11:05 PM
use 20 micron filters on your panel air venting systems and just wash off the dust from the filters whenever you do maintenance . . . you can also install a dust collection scrubber in the air circulation system if your atmosphere contains too many particles . . .
you must also conduct some verification of ratio of air volume to equipment volume inside your cubicles . . . the weight and surface area of the equipments and cubicles will also be needed along with the watt losses and durations of use during on periods . . .
if you show us the IGA of the panels it will be good . . .
to help you more we recommend that you collect air samples and test the same to find the particle size, composition and v/v density . . .
once you have the data we will be able to design a foolproof custom solution for you . . .
08/14/2011 12:21 AM
You are right.
The maintenance contractor should have vacuum cleaner. It's not good to blow the dust to the air.
The small dust particle can be infected other part such as ACB and other in the particular panel.
Yes we can not protect all dust to be collected, but at least we minimize the risk by using vacuum cleaner.
Romeo
Good Answers: 117
08/14/2011 3:42 AM
don't you have vacuum cleaners on your world?
Good Answers: 804
Re: Switchgears Preventive Maintenance
08/14/2011 11:56 AM
It's actually a very common problem, "cleaning" is often considered a lowly task left to the people least likely to understand the consequences of their actions. I have done numerous mining equipment electrical containers that need filtered air ventilation and I get frustrated with either a complete LACK of cleaning, or cleaning procedures such as what you describe, which are more akin to "recycling" the dust. I have had moderate success in changing bad habits by simply putting on a sticker that says something like
"Danger! Improper or incomplete cleaning of filters can lead to arc flash events and exposure to extreme electrical danger! Perform regularly scheduled cleaning in another area using a vacuum cleaner ONLY."
It may not be 100% true, but to the people who are often left with the task it might as well be scripture!
Good Answers: 170
08/16/2011 11:11 AM
It is a very elementary concept in cleaning any electrical system/equipment that it should nevr be cleaned by blowing air. The best method is to use a vacuum cleaner. Even a apprentice electrician would know this.
Register to Reply 6 comments
brich (1); electricalexpert65 (1); JRaef (1); Lspraba (1); Romeo2010 (1); soebfatehi (1)
