our UPS (uninterrupted power supply ) system has a single phase ,230 VAC inverter module fed by a 110 VDC battery bank. at the ouput of the inverter is a single phase 15KVA transformer and 2 No capacitors of 200μF are connected across secondary terminals of this 15KVA transformer . what is the purpose of this 15KVA transformer and the 200μF capacitors ? is the transformer for stepping up the 110VAC at the o/p of inverter ( which was originally 110VDC at i/p of inverter from battery bank ) to 230VAC ?
