Previous in Forum: Wireless transmission of electrical energy   Next in Forum: Cable tie a C.P.C to a exturnous pipe work
How Are AC and DC Motors Alike
04/19/2007 11:59 AM
I must know!!
Friend of CR4
Re: How Are AC and DC Motors Alike
04/19/2007 12:04 PM
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
04/19/2007 1:07 PM
because it follows then that when a motor is powered from a supply and is runing at full speed it will be generating a voltage. As determined from lenz's law. This induced E.M.F is opposite in direction to the supply voltage it is known as back E.M.F. This generated voltage is always less then the supply voltage due to the voltage drop in the armuture windings. This works in both AC and DC
04/19/2007 2:54 PM
They both spin because of the electro repulsive effect. DC direct current uses coils and permanent magnets. AC alternating current uses a voltage that goes positive and then passes through a zero voltage to change polarity to a negative voltage (sign wave) you can also get a square wave where the wave shape is like that of a squared off shape vertical to Begin flat across the top and back down to cross over and go horizontal before going back up again; this repeats for as long as you like.
AC is used because it can be transformed up or down in voltage you can only convert down with DC unless you use a chopper supply.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
08/21/2024 11:01 AM
The output shafts of both rotate and can be coupled to devices to transfer energy from the electrical supply to the load.
That's about it.
Anonymous Poster (1); BrainWave (1); Chris Leonard (1); PWSlack (1)
You might be interested in: DC Motors, AC Motors, AC-DC Adapters
