Previous in Forum: Meaning of "Q max", "H max", and "suct Lmax" on a Water Pump?   Next in Forum: Flow Losses Associated with 90 Degree Sharp Bend
8 comments
Hobbies - Automotive Performance - Dirt Tracker
Need Help Identifying Thread Form
08/17/2011 9:42 AM
I need to specify what thread form this is, and I cannot find any information on what it might be. The part is used in drilling operations, but other than that, I do not know anything else about its use.
Here is a picture of the thread:
http://www.yfrog.com/h8ie3otj
For scale purposes, the effective length of the thread is 1.75", and it is a 7 degree taper. 5 threads per inch (Pitch= ~0.200")
Let me know if you can tell me what thread form this might be. Thanks!
Dirt is for racing, asphault is just for getting there.
Good Answers: 299
Re: Need help identifying thread form
08/17/2011 11:36 AM
Here is the image:
Perhaps a variant of Stub Acme thread? Doesn't look quite right. What is it for?
08/17/2011 12:07 PM
It is off an attachment for an AWJ Drill Rod. I just found this out, and am going to contact the manufacturer right now.
08/17/2011 3:22 PM
Turns out this is oil field terminology. "WJ" is their name for the thread form, which is a tapered ACME thread. "A" refers to the size, with 1.75" OD being the smallest normally available drill rod.
Thanks for the help!
Good Answers: 299
08/17/2011 3:57 PM
Stop by anytime.
As our British friends say, "The kettle's always on".
I can't remember any of them actually saying that, but you get the idea
Re: Need Help Identifying Thread Form
08/18/2011 7:21 PM
This thread is used because it is course (of course) so it connects with few turns and it seals well.
If you've ever watched them pulling or installing drill stem, you've seen this thread.
Cheers.
Good Answers: 299
08/18/2011 7:35 PM
I should have picked up better the comment in the OP "...drilling operation..."
I assumed (incorrectly) along the line of a drill press. I should have picked it up from the visible taper. It is, however, a form of the Stub Acme thread, so I was on the right track.
The AWJ thread is (it is said) impossible to cross-thread. This makes it a fast and reliable connection in a very fast-paced operation.
Good Answers: 150
08/19/2011 11:01 AM
A lot of this kind of data can be found in Baker Oil Tools Techfacts which is available on the web. I believe this to be a cable tool joint (see page 12 of the Baker Tech Facts above)
Who is John Galt?
08/19/2011 11:29 AM
Great link. Thanks!
Register to Reply 8 comments
Doorman (3); ericg78 (3); lyn (1); Rorschach (1)
