Previous in Forum: Load Distribution   Next in Forum: Forging Test Coupon
10 comments
Laboratory Stirrer
08/18/2011 10:41 AM
Hi . every body. I am extermely happy that there are a few people to sort my doubt. Sirs- I am a chemist - I do not know any eng. Pl excuse me. But I have a small problem . I want to make my own Lab stirrer. I do not want the carbon brush type motors. The power i need is very small ! 1/8 HP . This has to stirr just ~ 500 to 1000 ml of say castor oil - viscosity. II do not want complicated controller etc. In this connection - I have heard about stepper motors. Will this work ?/ Pl help.
VIJAYAKUMAR - CHENNAI
Re: LABORATORY STIRRER
08/18/2011 10:48 AM
Good Answers: 48
08/18/2011 11:00 AM
1/8 HP sounds a lot for stirring just 1000ml of castor oil. I would have thought just a few whats would be enough.
What speed, or speed range, do you want the motor to cover?
A stepper motor would be ok for slow speeds (less than, say, 1500rpm), but still needs a controller.
A small BLDC (brushless dc) motor with integrated controller might do the job.
08/18/2011 12:52 PM
SIR,
Thank you for the interest shown. The RPM will be 10 to 100 only. But this should be contant ie iI mean - with increase load the stirr ing should not decrease.
Good Answers: 48
08/18/2011 2:14 PM
In that case a small stepper motor (or servomotor) could be used. It will run well at these speeds, and can be controlled for constant speed. The alternative would be a BLDC motor with a gearbox.
08/18/2011 11:12 AM
What comes to mind is a variable speed rotary tool.
Shown is a DREMEL™ Fortiflex. This one has variable speed 0-20K RPM, heavy duty flex shaft... blah, blah, blah. This is simply an example, there are many manufacturers of this sort of thing with many options.
08/18/2011 11:17 AM
08/18/2011 11:38 AM
I am not sure I would select that to stir 2 cups (or 16 ounces, or 500ml) of liquid.
Good Answers: 53
08/18/2011 1:11 PM
Magnetic stirrers are widely used for that much of qty, example (Its not an endorsement)
08/18/2011 1:28 PM
Respected Sir,
Thank you.for the time sparred.
But sir,
If I want to conduct an experiment , reaction involving heatuing / etc I have to put up only in geared type of stirrers only . I have worked with some german company- ie - where the stirring rod can go thro the chuck / & they are very compact. The motors were very small.
I wonder like tihs type are not available in INDIA or I do not know what is the reason . i have seen REMI company products etc , but Ithough I am using their stirrer only I am not happy with the design or type etc.
Regards,
vijayakumar
08/18/2011 2:21 PM
Well, if somebody doesn't like the other idea, how about a real lab mixer?
These guys make all sorts of them.
Register to Reply 10 comments
Anonymous Poster (2); charmachem (2); Doorman (3); Holzfeller (2); rakesh_semwal (1)
