Previous in Forum: electricalexpert65   Next in Forum: Radioactivity in Fracking Overburden
Max Allowed ZS for Schneider mccbs
08/18/2011 11:21 AM
can anyone tell me where i can find max zs values allowed for schneider type mccbs ranging from 32amp to 800amp . thanking you
Good Answers: 804
Re: max allowed zs for schneider mccbs
08/18/2011 2:05 PM
zs? Do you mean Zero Sequence current? Do your MCCBs have ZS protection built-in, as in having external core balanced Zero Sequence Current Transformers (ZSCT)? If not, ZS is a non-issue, a strandard MCCB will not be capable of detecting nor reacting to a Zero Sequence current siutation directly. Even if you were referring to solid state MCCB trip units, they will typically have Residual Current detection for ground (earth) fault detection, ZS is an option because it requires that external ZSCT.
Assuming that's what you mean by "zs".
PS: We can't read your mind and acronyms have lots of different meanings, even in the same context.
Good Answers: 181
Re: Max Allowed ZS for Schneider mccbs
08/19/2011 5:49 AM
Maximum values for Zs are in BS7671-2008. They aren't manufacturer specific. Or contact the manufacturer.
Good Answers: 804
08/20/2011 1:35 PM
So Tony, what is Zs in this instance? Source impedance?
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
08/21/2011 1:18 AM
zs-> earth fault loop impedance
http://pws.schneider-electric.co.uk/internet/pws/literature.nsf/luAllByID/NKIY-5JUHSL/$file/MGD5032_section2.PDF/
page-6........................
Zs= Uo/Ia
Where
Zs = Maximum earth fault loop impedance.
Uo = Nominal phase voltage.
Ia = Current ensuring automatic operation of the protective device.
Ia for circuit breakers is the mean tripping current as follows:
Type B = 4 (typical)1 x rated current
Type C = 7.5 (typical) x rated current
Type D = 12.5 (typical) x rated current
Ia for fuses are appropriate mean values from AS 60269.1
shamith gambhir, electrical engineer
Register to Reply 4 comments
JRaef (2); SHAMITHGAMBHIR1 (1); TonyS (1)
