Previous in Forum: Fast Switching Device   Next in Forum: About Ratio of Sodium Bicarbonate in Water for LRS
AC Current Measurement Deviation from Theoretical Calculation
08/19/2011 9:33 AM
Hello All,
I am trying to measure the current drawn from the 230vac mains with varying load from 25w upto 360w with the ACS712ELCTR-05B hall current sensor from Allegro.
The hall sensor senses the load current after the relay is switched and 230v is connected to the load. The voltage signal from the sensor output is then high passed filter by rc passive filter (r=100K and c=0.1uF give fcutoff of 15.915Hz,is that correct?) before amplified by 3.77 times by low noise op amp. This is then fed to an ADC.
The actual measurement results differs from theoretical calculation using combinations of 25w, 60w and 100w to simulate resistive loads from 25w to 360w. The A/D converted values vary from measured slightly less than theoretical at 25w to 100w after which the measured values start to get larger than the theoretical calculation from 100w onwards.The difference gets quite large at 200w onwards.
Does anyone know what is the reason for this? The ac load current is measured with an ammeter (rms) when the relay is energised but the ammeter reading is consistent with calculation.
I suspect it could be the passive rc hi pass filter that causes this problem but this filter is needed to remove the Vdd/2 dc offset from Allegro sensor output at zero load.
IS there anyway to solve above problem?
Any help would be appreciated.
Thanks!!
Re: ac current measurement deviation from theoretical calculation
08/19/2011 9:44 AM
Basically you have the classic measurement problem.
You need to calibrate your instruments agaianst some known reference, (say a watt meter) not against a theoretical reading.
The errors could be anywhere in your present set up and theoretical means zip.
You can maybe hire or borrow a suitable instrument to give you a spot calibration.
08/19/2011 11:36 AM
Exactly correct Del, GA.
The root cause of this error can be anywhere from inaccurate loads, measurements, to even incorrect theoretical circuit analysis. The OP must calibrate their measurements to real reference standard devices.
The key for the OP to understand where the analysis error happened will be to go over the analysis method with somebody else and comparing the difference between measured and expected results. It is very easy and even common to forget that a design guide is actually an inaccurate approximation.
I have a few likely candidates for the OP.
1. Your single pole high pass filter should attenuate a 15.9 Hz by 3dB, but only at ∞ Hz will the attenuation be 0dB. Does your analysis include the expected attenuation at your power distribution frequency?
2. The high pass filter and every component in your signal path to your A/D will be loaded by the input impedance of the next circuit. Was this included in the analysis?
3. Was the amplifier gain calculated from the ideal amplifier equation with ∞open loop gain or from a real, precise finite amplifier gain equation?
4. All linear electronic parts are really only linear in a certain range of values. The compression you're seeing may just be an early indication of one part in the chain being too close to a signal maximum.
5. All parts but particularly capacitors have parasitic attributes that make them less than theoretical ideal parts.
Register to Reply 2 comments
