Previous in Forum: Vector Group Vs Price   Next in Forum: Linear Actuator Trim Tab
8 comments
Series Couplers
08/22/2011 12:31 PM
my understanding of coupler is a circuit breaker between two buses used to supply power from one bus to other bus loads in case supply of the other bus fails. a single circuit breaker , i think, is sufficient for this.but i have seen scenarios (in my own workplace ) ,where two series couplers are used for this purpose as shown below : now what is the purpose of two series couplers ( besides increase in cost ) if one coupler can do the same job ?
Good Answers: 44
Re: Series Couplers
08/22/2011 12:50 PM
This practice allows remote locations the ability to control power feed into panels and subpanels. If you had two or more feeders for a facility and had the ability to power the facility from either one through the use of couplers, you would want the ability to open or close the feed at the remote service.
If a facility allowed distant couplers to control the feed to another building or plant location that they had no communication with, it may cause damage or injury to the remote section or personnel.
An operator would close the feed and then either close the remote feed themselves or contact a remote operator to do so.
Re: Series Couplers
08/22/2011 12:59 PM
Is Bus A and Bus B located in the same switchboard? I feel one B/C shall do the job in such case.
However, if Bus-A belongs to Swbd # X and Bus-B belongs to another Swbd # Y (in same or distant location), interconnection of these two buses requires Bus coupler on either sides for positive isolation in case one has to work on the interconnected part with both Swbd # X(Bus-A) & Swbd # Y(Bus-B) live.
Good Answers: 125
Re: Series Couplers
08/22/2011 1:40 PM
Couplers are also used to "couple" the two buss sides together for purposes of transmitting low level data throughout a facility. In this case no power can cross over from one buss to another, but the data transmission can occur.
Good Answers: 44
Re: Series Couplers
08/22/2011 1:44 PM
Is this what you are referring to:
http://www.rpsswitchgear.co.nz/products/bus_coupler.html
...or is it a data coupler as WJM states?
Re: Series Couplers
08/22/2011 1:56 PM
the two buses belong to different switchboads and the two switchboards are located next to each other. also, the two couplers have communication with control room for ON/OFF and are not used for any other data communication purpose.
Good Answers: 244
Re: Series Couplers
08/22/2011 8:17 PM
The way the couplers (in North America it is called Tie-In-Breaker) are installed (located next to each other), I don't see any other reason for having two couplers in series except they facilitate the maintenance with completely de-energizing them with having power in one of the switchboards.
- MS
Good Answers: 44
Re: Series Couplers
08/23/2011 10:08 AM
That was my point in post 1.
Re: Series Couplers
08/23/2011 9:34 AM
generally two coupler connected in series for maintainance purpose where bus shutdown is not possible(for chemeical/processing factories). with one bus shutdown you can do maintainance on connected coupler with that bus & vice versa.
Register to Reply 8 comments
coolyaar (1); cuba_pete (3); hbadhan (1); msamad (1); subhash wad (1); WJMFIRE (1)
