Previous in Forum: Solid State Stabilizer   Next in Forum: Series Couplers
16 comments
Vector Group Vs Price
08/22/2011 10:20 AM
Does the vector group affecting the price of the transformer?
For example, the 2MVA Dd transformer is always cheaper than 2MVA Dy transformer?
Or the price only determines by the capacity of the transformer?
Pathfinder Tags: Vector Group Vs Price
Re: Vector Group Vs Price
08/22/2011 10:30 AM
Which country?
India - Member - New Member
Good Answers: 164
08/22/2011 10:50 AM
i have absolutely no idea, having zero knowledge in this field. i am eager to see experts give their responses...
But i think, is it logical ? If one was cheaper, why would anyone want to buy a more expensive one just for a neutral (or absence of one)? i await with bated breath....
Good Answers: 42
08/24/2011 12:10 AM
The decision to go for DD/DD or DD/DY mainly depend on your requirement . If a step up transformer for EHT transmission ( 11kV to 220 kV or 400 kV )can be DD/ DD as the transmission is 3 phase 3 wire and there is no requirement of neutral . Where as in case of a 3 phase 11kV /430 V transformer for LT distribution transformer Neutral is a must as the distribution will be 3 Phase 4 wire system necessary to provide 230 V line (220/110 V in case where that voltage distribution system prevails)to neutral supply to single phase consumers .( Only if the complete load is purely 3 phase delta then DD /DD transformation system can be used.So it is not financial consideration but technical requirement by which decision is taken.
08/22/2011 10:52 AM
Who on earth are you getting quotes from?
08/22/2011 11:03 AM
A Dd transformer, needing no neutral terminal, is a simpler piece of equipment.
08/22/2011 11:34 AM
It also means cheaper? I'm asking because I have to change the vector group of 3 winding transformer from Dy5 Dy5 to Dy5 Dd0.
Good Answers: 131
08/22/2011 12:16 PM
It MAY be less expensive, because the manufacturer needs to install one less bushing (and associated hole in the tank, bushing flange, cable, etc.), but you cannot be sure until you get a quote. There may be other considerations such as the size and length of the conductor used in the delta vs. wye winding, the amount and type of insulation used, how the winding is blocked and braced, etc. There are many factors, so it is impossible to make a generalized statement that delta will cost less than wye.
There are other considerations for your electrical system to consider. Can you adequately protect for ground faults if you don't have a neutral from the transformer? How will you protect for ground faults? Are you loads all 3-phase motors, or are there single-phase loads also.
Be careful when you say "I can just change it to a delta winding" without examining all the impacts. "Cheaper" often comes with an unintended price!
08/23/2011 8:40 AM
Get some proper quotes and find out!
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
08/23/2011 12:12 AM
In three phase transformer of 1:n ratio
for primary (V,I) there is (n.V, I/n) secondary in case of Delta-Delta.
(n.√3.V, I/(√3.n) Delta-Star.
(n.V/√3, √.I/n) Star-Delta.
(n.V,I/n) Star-Star.
These parameters are important while selecting capacity of transformer.
08/23/2011 2:02 AM
I think Yes,
Let us consider 2 MVA 6600V/440V trafo.
Pirmary current = 2000/1.732* 6.6= 174A
secondary current=2000/0.44=2600A
In case secondary is delta, line current is 2600A. But Each winding need to withstand 2600/1.732= 1501A
But in case secondary is star connected, each winding need to withstand 2600A.
So the increase in winding thickness increase the price.
Am i wrong or correct?
08/23/2011 3:43 AM
You are Wrong.
Your Formula for the 2ndary is missing the 1.732:
S = UxIx1.732 ==> I primary = 2000 x 1000 /(6600 x 1.732)
I secondary = 2000 x 1000 / (440 x 1.732)
Even though you got the answers correct in those lines.
The current in both cases will be the same in the windings.
08/24/2011 1:30 AM
Thank you for correction.
Consider the case 1:
Two numbers of 2 MVA trafo with same specification of primary/secondary voltage, but one is DD and other is DY. Let us consider 6600/440V
A)
In DD trafo, secondary is delta. So voltage across each winding in secondary is 440. i.e. 440V is induced in each winding.
Phase current =1.732* line current
Line current =2600A
Current in each winding or phase is -1501A (as already mentioned in pervious post)
B)
In DY trafo,
Secondary line voltage = 440V
Phase voltage =440/1.732 =254V
So voltage induced in each phase= 254V.
Line current = phase current =2600A.
Conclusion:
· In DD number of secondary turns in each winding would be higher than the DY by 1.732 times (according to the voltage induced (440/254V))
· In DD secondary winding thickness would be lesser than DY (according to the current capacity(1501/2600A))
These points also affect the price.
Consider the case 2:
Two numbers of 2 MVA trafo with different specification of primary/secondary voltage, but one is DD and other is DY.
Let us consider 6600/440V in delta
6600/762V in star.
In these case the same trafo secondary can be converted from Delta to Star. No changes in thickness and turns ratio.
08/24/2011 3:09 AM
Correct ! GA for you.
Good Answers: 164
08/24/2011 4:42 AM
Conclusion:
Er.... more turns of less cross-section vs less turns of more cross-section....do you thing that copper will be less in one? If you do detailed calculations, you will realise that there is no free lunch in the world....both will be the same.
08/26/2011 10:51 AM
Yes Sir,
They do not affect the price much, but affect.
10/15/2011 11:14 PM
At low voltage, cost of conductor is the main concern.
At High voltage, cost of insulation is the main concern. (Delta winding voltage is √3 times higher than star- So insulation cost & thickness rises)
Register to Reply 16 comments
Anonymous Poster (1); hithuanand (2); kvsridhar (2); LAA_Lucke (1); Local_Eng (1); Lspraba (4); PeterT (1); PWSlack (3); V.I.Abraham (1)
