Previous in Forum: American Made Tungsten Electrodes for Welding   Next in Forum: Torx or Studwelding
8 comments
Polar Mohr Eltromat 72
08/22/2011 1:40 PM
Does anyone know the size and thread for the shoulder bolts used to engage the clutch so that I can manualy raise the blade on a polar mohr eletromat 72. I have no paperwor or tools/parts for this machine. Any help would be appreciated
Re: Polar Mohr Eltromat 72
08/22/2011 2:07 PM
Try one of these.
Good Answers: 151
08/23/2011 8:12 AM
M10X1.5 Shoulder dia. is 15mm length of 10 mm section is 3-1/8" threaded length is about 1". I have one in my hand.
08/23/2011 9:20 AM
Thank you for the information. Heideberg Eastern carries the tools for the machine. But what they call the clutch handle looks like a threaded t handle. I want to order one but I wanted to make sure that I order the right tool. i meassure about 4 inche to the first thread on the inside of the clutch. Am I looking at this wrong?
08/23/2011 12:16 PM
Do you think that 2 of these might work?
http://www.mcmaster.com/#metric-shoulder-screws/=dqumxq
Good Answers: 151
08/23/2011 3:43 PM
No, But you could use a M10 socket head cap screw 6" [150mm] long, and a 3" length of pipe or tube with a 10mm ID to form the shoulder. the shoulder is necessary to release the brake when you tighten the screws.
08/24/2011 6:32 AM
Thank you very much. That worked perfectly. The machine is up and running now. They wanted $227.33 each for the clutch handles and it cost me like $14.00 to make. Once again the help was very much appreciated.
08/24/2011 8:38 AM
This has 'Good Answer' written all over it. Well done.
08/26/2011 12:38 PM
I have another issue with this machine. The resistor that I replaced is on tits waay out. I reblaced the blown resistor with a 47 ohm 11 watt resistor and its melting. There must be an issue with something else. I dont have any prints or diagrams. do you know of any reason for this to be happening or where to begin looking. Any help would really be appreciated
Register to Reply 8 comments
DanielSimao (4); Doorman (1); gringogreg (2); lyn (1)
