Previous in Forum: Linear Actuator Trim Tab   Next in Forum: Bulb Blow Out
10 comments
India - Member - New Member
Cable Voltage Drop Calculation
08/23/2011 2:23 AM
dear all,
we are planning to construct a long conveyor from mines to plant.the distance is approximately 35KM.for material conveying 5 no's 11KV motor shall be used for different distances.my question is. in that 11KV cable is more economical or 11 KV overhead system.
next is if we are using 11 KV cable what about the volatge drop. i have calculated the volatge drop.but the thing is first motor i have calcualted the motor volatge drop. then how shall i find out the second motor voltage drop.because all the 5 motors are connected in loop in & loop out arrangement.all the motors shall run one by one.so starting volage drop is not on issue.so kindly help me in this regard.
regards,
N.Ganesan
Knowledge Sharing
Re: Cable volatge drop calculation
08/23/2011 5:01 AM
11kV is not the sort of stuff for the untrained to play about with. So, hire a competent Electrical Engineer to solve the problems.
Good Answers: 181
08/23/2011 6:03 AM
Your going to start a 35KM conveyor in one start, all be it with 5 motors?
I wish you luck!
08/23/2011 6:09 AM
it will be with 5 motors
Knowledge Sharing
08/23/2011 8:24 AM
It might be easier to build a railway between the places.
Good Answers: 181
08/23/2011 2:03 PM
You're seriously going to start 5 motors driving a 35KM conveyor?
You need your bumps feeling.
Re: Cable Voltage Drop Calculation
08/23/2011 3:33 PM
How are the motors being controlled? It sounds like you are wiring them so they can start in sequence one after the other, with the motor speed being slowly increased to prevent catastrophic equipment failure.
Can you provide more information please.
08/24/2011 12:26 AM
thanks for your information.
the thing is our project team is proposed conveyor(type of conveyor not mentioned.) for through out the length.so they are asking electrical team for techno commercial feasiblity.
still we are searching the details in this regard. for example we are putting 3 feeders for every conveyor motor like incomer feeder(getting power from previous feeder),motor feeder(supply to motor),outgoing feeder( loop in-loop out).if motor is fixed speed in this option is ok. for variable speed application we have to consider 690V converter duty motor,690V drive & 11/690V converter duty transformer(with OLTC=+/- 10%).for controlling the motor start we shall go with any wireless or radio frequency.Kindly send your suggestion.
Knowledge Sharing
08/24/2011 3:27 PM
It sounds like you just need to consider the 5 loads (voltage drops) connected in a series arrangement and size the cables for the expected starting and operating currents accordingly.
If you are using a ring main system (which is still a little unclear) with the possibility of powering the conveyor motors from either one end or the other then you would need to size the cabling for being powered from either direction (in which case the cable size would be large at both ends and may reduce in the middle).
08/23/2011 4:44 PM
In my world 35 km = 21 miles. That does not seem reasonable. Has it been done before? Utilities find that the overhead line will be cheaper to build. What size motors? I assume the motors will be equally spaced along the 21 miles.
08/23/2011 9:54 PM
your question is not clear enough...a rule of thumb we practice here is having your cable sized up at higher voltage with respect to the operating voltage..this is to compensate for in rush currents, voltage drops, and etc..you say your motor is operating at 11kV system, if i were to size up your cable i would go for 15kV rated cables at same operating current level with your 11kV one...
if you're worried enough with your voltage drops, how about stepping up your voltage to a much higher level...
take care of your seconds and the minute will take care of itself..
Register to Reply 10 comments
ganeshakce-electrical (2); jack of all trades (2); PWSlack (2); rockraiden (1); TonyS (2); wareagle (1)
