Previous in Forum: Analysis the service life of rotary dryer   Next in Forum: Constant Current Technology--led module
LED LiteBar
08/24/2011 1:03 AM
Under developing, TECLED modular LED strip light / LED Linear Light - LED LiteBar 3 and LED LiteBar 5 will be anounced within 2 months. This system will be have two
brightness choice as followed:
LED LiteBar 3 come with 21 3528 high brightness SMD LED, output 150 lumens / foot, Each strip
consume 1.8w electrical energy.
Both LiteBar 3 and LiteBar 5 use 1mm thickness fiber glass PCB which have a good physical
characteristics and good heat conduct performance. The LED strips / Bars can be cut every
3 LEDs segment. The cutting area will be indicated clearly. Both ends of strip have a intergrated
quick connector for connecting to power supply or join to another LED strip.
We knows accessories are very important part of a successful product, They will save you valued
time and make your project looks perfect. Like all other TECLED product, LiteBar 3 and LiteBar 5 will
come with full range of accessories like optional aluminum sheild, joint cap, end cap, 90 degree coner
cap, extension cord...etc
http://www.ledmodulelight.com/flexible-led-strips1.html
Also posted in: also posted in General Discussion
Re: LED LiteBar
08/24/2011 1:30 AM
Commercial Alert!
Re: LED LiteBar
04/17/2012 12:33 AM
The LED Strip Light is available in various voltages one among them is 12 volts.I had gone through the site. The competitive LED Strip Lighting products from various manufacturers ans LED Strip suppliers are more helpful for us in various tasks. In the mean while we can also provided by the LED Strip Lighting products such as Led Ribbon, Led Lighting, Led light strip, Led light bar for our choice. High Color Rendering Index LED strip light we use high Color Rendering Index . The lighting color is equal and colorful. The products make 3 leds as a unit and we can cut into different length.
led lighting Melbourne
led flood lights
Re: LED LiteBar
04/17/2012 12:59 AM
Et tu, Brute.
Register to Reply 3 comments
