Previous in Forum: Positive Material Identification   Next in Forum: Failure Analysis Screw Driver
ss welding without purge gas
08/24/2011 9:46 AM
SS welding can be do without purge gas with gtaw welding. GTAW welding without shieding gas not possibe. But without purge gas, by using flux coated filler wire it possibe to weld ss material. During welding these flux coated filler wire providing good weld slag or porasity or oxidation.
Palasamind
Good Answers: 150
Re: ss welding without purge gas
08/24/2011 10:02 AM
Is this a question or a statement?
Who is John Galt?
08/30/2011 11:55 PM
It is statement. We used to weld as hook up joint. Without oxidation, porosity and slag inclusion. Also these joint is passed with 100% radiography and IGC test.
palasamind
08/24/2011 10:12 AM
Without gas, it isn't GTAW.
Using flux coated wire may, or may not, give good results. That depends on many factors, none of which we know, at the moment.
08/25/2011 6:34 AM
Using flux coated wire its ok but results of the welding whit gas is better.I have experience whit this tip of welding and i prefer GTAW.I thing GTAW is perfect.
Register to Reply 4 comments
Anonymous Poster (1); lyn (1); Rorschach (1); welding eng (1)
