Previous in Forum: Problems With a 405KVA CKD SKODA Diesel Generator Set   Next in Forum: DO ASTM A325 bolts need a charpy V- Notch impact test
Lifting Lugs Specification
04/20/2007 4:33 AM
I am building a power pack which is to be contained in a carbon steel crash frame. The frame is to be capable of lifting by overhead crane via slings so I want to weld lifting lugs at each corner.
The max gross weight of the power pack and frame etc. is 1050kg.
I would be grateful if any our readers have knowledge of, or where I can obtain detailed specifications and drawings for suitable lugs.
HydroScot
Re: Lifting Lugs Specification
04/21/2007 1:17 AM
1050 Kg is very nice load, so you can use 2 lifting lugs with thickness 13 mm x length 120 mm x height 150 mm to be welded all-around to crash frame with fillet weld 12 mm size. The lug must be furnished with a hole dia. of 30 mm.
If the thickness of crash frame at zone of welding is less than 8 mm, you can use a pad under the lifting lug with dimensions 160 mm x 60 mm x 10 mm to be welded all-around with fillet weld size 8 mm.
05/22/2008 8:12 PM
What is the design procedures for designing lifting lugs?
04/21/2007 6:55 AM
hi there the most important thing about a lifting lugs is the the thickness of the material being used. i am a tradesman in australia an i have never seen a design for lugs most trade'ys use a 75x 10/12 flat bar about 100 long with a radius end with a 30mm hole drilled in the plate
04/23/2007 4:31 AM
I appreciate the response from both reporters to date, but would like to obtain details of formal specs e.g BSS or similar as the lugs will need to be load tested and certified.
03/03/2009 12:04 PM
try
ASME Code Section VIII, Division 1, Boiler & Pressure Vessel Code, Latest Addenda ASME Section IX, Welding Code Pressure Vessel Handbook 13th Edition by Eugene F. Megyesy
Abdel Halim Galala (1); Anonymous Poster (3); HydroScot (1)
You might be interested in: Lifting and Rigging Attachments, Lifting Jacks
