Previous in Forum: Instrument Engineering   Next in Forum: More Relativity - Absolute Rest?
8 comments
Incoloy Elements Failing in Stainless Steel Tanks
04/20/2007 6:09 AM
I am at the end of my teather with this "work related issue:" our company has just released solar hot water systems which are comprised of stailess steel tanks (no anode) with a heating element made with incaloy. Now we are experiencing unaceptable failure rates of these heating elements and seniour management seem to think it is related to the rubber seal leaking between the element flange and the tank.
We also use these elements in our conventional electric storage tanks which have anodes in them, and virtually no failures. This is why i disagree with the argument that it is caused by moisture seeping past the seal and more to the fact that there must be some sort of " catode/anode" effect with the stainless tank and the incaloy element.
It also interests me that every element failure shows the failure spot/rust spot on the left hand electrical connection to the element.
It would be most appreciated if someone could shed a different light on the subject.
kind regards
Re: Incaloy elements failing in Stainless steel tanks
04/20/2007 6:18 AM
Assuming the heated medium is water, what is the pH (acidity), the total dissolved solids [TDS] and the total suspended solids [TSS]?
corrosion chart
04/20/2007 7:24 AM
Hard to say. these failures are metropolitan wide with no hot spots in one paticular area. if i can answer this in any way by saying that all failures are using water within Australian Drinking Water Standards.
04/20/2007 11:57 PM
Slack, salinated water make an electrolyte, provided the tank/electrode act in bimetal fashion. A battery/capacitor formed?
04/20/2007 8:12 AM
You're working with AC power, as a domestic application, right?
Humm... suspicious you are...
Good Answers: 40
Re: Incoloy Elements Failing in Stainless Steel Tanks
04/20/2007 10:27 AM
Water itself is corrosive, An annode on the stainless steel will only protect the stainless steel. The element should be isolated from the stainless steel box. If it is not, a short could develop. The annode will not protect the element.
Incaloy is used as a coating for elements to protect it from the corrosive elements of the water and dissolved chemicals.
It may be possible that:
  1. the manufacturing or installation process is damaging the Incaloy coating in the one spot, or
  2. the insulation is damaged due to inadequate packaging or rough handling during transport.
Good Answers: 40
04/20/2007 10:35 AM
Sacrificial Annodes require electrical continuity to be effective.
04/20/2007 2:41 PM
You are * correct, analyse the differences between the 2 systems insomuch as they vary.. and thats where to attack problem. Clue, utility companies use small bias chargers to prevent water & gas pipe failures...the presence of a repeated location...indicates electrical activity. a sacrificial rod may be the easy fix here.
Google search marine techniques for dealing with spurious electrical/ionic buildups. Your challenge falls into that category.
*"This is why i disagree with the argument that it is caused by moisture seeping past the seal and more to the fact that there must be some sort of " catode/anode" effect with the stainless tank and the incaloy element."
04/23/2007 7:20 AM
Yeah, your failures are near the element root just because this is probably the nearest point to the sst walls. Temperature up, and you have a good corrosion accelerator.
If contamination os not a problem, a sacrifice anode and a small current rectifier could do you active cathodic protection for (almost) a life.
Register to Reply 8 comments
Anonymous Poster (1); bhrescobar (2); PWSlack (1); richie rich (1); techno (2); Yuval (1)
