Hello everybody, warm regards for the day.
I have a small doubt regarding transformers. Assume that we have a 6.6 KV / 415 V transformer and that the transformer is charged through the 6.6 KV HT panel feeder, where as the LT side supplies a PMCC panel. Now suppose there has been a huge short circuit in one of the feeders of the PMCC panel and there is a considerable voltage dip on the LV side because of this. (say the voltage now is some 380 V for a very short period of time). Does this decrease in voltage effect the HT side voltage?? I mean will there be a decrease in the HT side voltage as well (To maintain a constant value of transformation ratio)? If no, is it logical enough to say that the transformation ratio of the transformer has changed for that particular period during which the fault persists or till the time the fault is cleared?
Thank you all in advance.
