Previous in Forum: 3 Phase Induction Motors   Next in Forum: Help Needed Balancing 3-Phase House System
11 comments
Motor/Equipment Paint for Hazardous Area
08/31/2011 6:40 AM
Please help me to know the type of paint that can be used for a motor located in hazardous area?
Re: Motor/Equipment Paint for Hazardous Area
08/31/2011 7:07 AM
Eh? Of what relevance is the paint to the hazardous area?
Good Answers: 181
08/31/2011 7:12 AM
Fluorescent orange was my favourite colour.
What paint and what hazardous areas are you talking about?
Good Answers: 266
08/31/2011 7:24 AM
Classification of the hazard would help. Most are finished with power coat epoxy.
08/31/2011 10:56 AM
Personally, I like blue paint.
08/31/2011 1:47 PM
Why not use the same as used for a safe area industrial motor?
Any epoxy based paint suitable for the specified environment condition should be OK.
Still curious to know more details from OP as sought by others.
08/31/2011 2:21 PM
I'd use the non-hazardous type.
Perhaps you sould re-phrase the question.
Good Answers: 125
08/31/2011 2:23 PM
"hazardous area" implies an atmosphere where a spark might create an explosion.
Do you actually mean "caustic area"? If so, what is the chemical the motor will likely be exposed to?
Good Answers: 244
08/31/2011 9:57 PM
There is no specific requirement of painting for the motors to be used in the hazardous (classified) locations. Use the paint which is suitable for the weather condition. Generally three-coat painting is good for the motor for wet, salty and corrosive weather. Two-coat is also good enough for regular weather.
- MS
Good Answers: 21
09/01/2011 4:30 AM
If the question supposed to be "what type of paint to apply on a motor in a hazardous area".
The recommendation would be a water, or other non-flammable based paint.
eg a thinners-based paint will provide a hazardous atmosphere around the motor as it dries.
However, the motor should be Ex rated in the first place, so it shouldn't matter at all.
09/01/2011 9:49 AM
Check with Rust-Oleum, Siemens or Sherwin-Williams or any paint/epoxy manufacturer. Give them the conditions and they can recommend the appropriate coating.
09/01/2011 1:48 PM
Unless you plan to paint while the motor is running hot in a hazardous area, the paint should be of no issue.
Register to Reply 11 comments
hbadhan (1); Hilton (1); JohnDG (1); lyn (1); msamad (1); Ninpoiken (1); ozzb (1); PWSlack (1); TonyS (1); vargaalex (1); WJMFIRE (1)
