Previous in Forum: Solar Power Battery Charging   Next in Forum: Earthing Conductor Sizing
Kvar to Farad Conversion
09/02/2011 9:20 AM
Does anyone know how to convert Kvar to farads ? and is there a chart for doing this ? thanks
Good Answers: 69
Re: electronics
09/02/2011 9:55 AM
Strictly speaking, you can't convert any parameter to another, you need at least a third component to do a reference.
You can only do that when working with scales (orders of magnitude), inverses or equivalences obtained by the use of a constant (wavelenght = speed of light/ freq.).
If you're try to know power factor correction capacitor values, do a search on that matter.
Re: electronics
09/02/2011 10:55 AM
thanks
Good Answers: 244
Re: electronics
09/02/2011 8:06 PM
See this thread: http://cr4.globalspec.com/thread/70684/Capacitors-Capacity (comment # 2 and 4)
- MS
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: Kvar to Farad Conversion
09/05/2011 11:51 AM
Eg. 117KVAR capacitors connected as star in 11KV side. Phase voltage =11000/1.732 is acting across each capacitor(6351V). The capacitive reactance Xc = 1/(2x3.14xfxc). Xc is given in ohms . Now Xc of 117KVAR = (6351)^2/117000. =344.74 = 2x3.14xfxc. c=344.74/(2x3.14x50). =1.09F.
Register to Reply 4 comments
hithuanand (1); karlf (1); msamad (1); Yahlasit (1)
