Previous in Forum: Inverter   Next in Forum: About AC Drive Circuit - 15hp Baldor
9 comments
UPS System
09/06/2011 6:54 AM
What is the difference in online UPS & offline UPS
Good Answers: 15
Re: UPS System
09/06/2011 9:27 AM
Re: UPS System
09/06/2011 3:45 PM
online UPS = parcel arrives
offline UPS = parcel doesn't arrive
"It's not the dress that makes you look fat. It's the fat that makes you look fat." - Al Bundy
Good Answers: 42
Re: UPS System
09/11/2011 12:14 AM
Off line or on line parcel arrives on dot time by UPS.So there is no difference ( Known by experience). Ofcourse joke.
On line UPS is always in circuit. Off line have to be pushed on when supply fails in simple terms
Good Answers: 44
Re: UPS System
09/06/2011 3:56 PM
Another thing I would add to soebfatehi's link would be that the "online" UPS usually supplies power from a double-inverter integrated into the UPS. This allows frequency adjustments and negates variations from the incoming voltage and frequency considerably. Basically, your load is powered off of the float on the battery bank or flywheel, dependent on your UPS type.
Good Answers: 244
Re: UPS System
09/06/2011 7:36 PM
On-Line UPS: The power flow is through the Battery Charger and Inverter under normal condition. The power flow switches to the bypass system if the UPS encounters a problem, such as failure or overloaded.
Off-Line (or Standby) UPS: The power flow is directly from the commercial source under normal condition. UPS is used only when the utility power fails.
- MS
Good Answers: 15
Re: UPS System
09/06/2011 11:04 PM
is it possible to build a kinda prospective ups wherein the impending loss of power is sensed and battery power is supplied in anticipation thus reducing the duration of lost power?
if this is not already being done then it can become the next big thing after Noah's ark . . . .
Good Answers: 44
Re: UPS System
09/07/2011 11:09 AM
When using the inverted output of the UPS there is no loss of power whatsoever at the output during interruptions or sags.
Good Answers: 244
Re: UPS System
09/07/2011 6:22 PM
The system is already been built and are running in place. Static Transfer Switch (STS) does the job of transferring from a failure (or faulty) source to another standby source (from UPS to Bypass for Online UPS and Bypass to UPS for Offline UPS system). STS monitors the condition of both sources and it transfers the load from failure (or faulty) source to the healthy source within few milliseconds (almost zero-break time) and thus the load doesn't experience the power loss during the transfer.
See this link for more about STS:
http://www.frost.com/prod/servlet/market-insight-top.pag?docid=7225997
- MS
Good Answers: 44
Re: UPS System
09/07/2011 6:34 PM
Alternately a static transfer switch can be used between two or more UPS', the UPS' and the mains, the UPS' and a generator bus, etc.
We have two UPS' running through a static transfer switch tied to a shared bus. The UPS' also have a static switch built into them to allow for a maintenance bypass. There are also maintenance bypasses installed upstream of the UPS' to allow for maintenance of the entire path.
There is such a plethora of configurations which allow maintenance of switchgear and equipment which never causes an interruption to the load.
Register to Reply 9 comments
cuba_pete (3); msamad (2); soebfatehi (2); thall (1); V.I.Abraham (1)
