Previous in Forum: Use of Soft Starter   Next in Forum: UPS System
9 comments
Inverter
09/06/2011 3:50 AM
In an inverter specification it is given as 48 volts battery input and ac output of (0....32V)*3, does this means that the output if 32Volt, is a Phase voltage otherwise a line voltage?What will the power equation at the output?
Re: inverter
09/06/2011 4:57 AM
32V 3-phase is unusual. Is this correct?
Re: inverter
09/06/2011 5:13 AM
Please give the make & model number of the inverter, and if possible a link to the datasheet.
Re: inverter
09/06/2011 5:35 AM
In an inverter specification they have given input battery voltage of 48V and output peak current of 200A (rms), then how do we know the output voltage delivered?
Re: inverter
09/06/2011 5:40 AM
We don't. Unless we read the datasheet.
Re: inverter
09/06/2011 6:05 AM
sorry i cannot find an option for attachment so please send me your email id....i will email you the detail sheet.
there is only option for uploading an image
thanks
Re: inverter
09/06/2011 7:06 AM
If the datasheet is available on line, you can just post a link here (then we can all access it).
Failing that, post the manufacturer's name and the inverter model number.
I'd rather keep my e-mail address private (unless there's no other alternative).
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: Inverter
09/06/2011 9:09 PM
The output voltage must me line voltage. RMS or active or effective value of AC is nothing but line voltage/Current. Peak value is 1.414xRMS.
Re: Inverter
09/09/2011 5:07 AM
my inverter has an output rating of 150 A nominal value and maximum of 400A having a battery input of 48V , the motor takes a full load current of 105 A, if the starting current is 4 times of 105 ie. 420A then should be the fuse rating be of 400A, and where should i place it, after the inverter or before it ie. after the battery from where it draws?
Re: Inverter
12/08/2011 12:34 PM
It still depends on the wiring.
Register to Reply 9 comments
hithuanand (1); JohnDG (3); PWSlack (2); sujinvipin (3)
