Previous in Forum: Allowable Stress for Bolt Material as per ASME   Next in Forum: Mechanical or Hydraulic Press
Welding ASTM B444 Pipe
09/06/2011 7:37 AM
Dear All,
I have to qualify a PQR for welding pipe ASTM B444 Grade1 as per ASME IX section. It is guided to use ERNICRMO-3 electrode. However the tensile strength of this electrode is much lower than that of base metal (i.e B444 grade 1) For instant minimum specified TS for electrode is 760 MPa while base metal is 827 Mpa. Probably if using this electrode the tensile sample will be broken at weld metal.
I am in double if it is acceptable or is there any other filler metal designed for this grade of pipe?
Thank you very much in advance for your advice.
Best regards,
Phu
Re: Welding ASTM B444 Pipe
09/07/2011 12:46 AM
contact a welding supplier. airco, ect.
09/07/2011 8:19 AM
If you are concerned with matching strength, I would suggest the use of like materials. Use Inco 626 wire to AMS5599. ESAB company has their "Arcaloy ER625" for use with the GTAW or GMAW processes.
Register to Reply 2 comments
