Previous in Forum: Adding Insulation to Walk-In Walls   Next in Forum: Threading Tools - NS Thread
Elevator Exciter
09/06/2011 5:21 PM
the polarity of a exciter has changed how do i change it back. battery?
Pathfinder Tags: dc polarity
Re: Elevator Exciter
09/06/2011 5:27 PM
Earth pole reversal has started? S.M.
09/06/2011 5:30 PM
Can someone tell me, is today the Bhadrapad Poornima?
Good Answers: 58
09/07/2011 9:41 AM
No, just exam week coming up
09/07/2011 9:43 AM
That would explain the current glut of this type of question from new members.
09/07/2011 6:43 PM
We're just on the cusp. Assume this is a bell shaped curve and, wait till 9-12-2011.
I'm off for a week of R&R, by myself. I'll miss the peak of the activity.
I ran an elevator in my youth and it never got excited.
Good Answers: 445
09/06/2011 11:26 PM
Before you do anything you should investigate the cause of the polarity reversal. There's usually enough residual magnetism in the rotor to cause the field to build up in the right direction unless it has been idle for quite a long time, so I'd be curious what has changed in the generator circuitry. Once you're sure it's just a lack of sufficient magnetism then "Flash it" with a battery through a current limiting resistor.
Register to Reply 6 comments
Anonymous Poster (1); Doorman (2); KJK/USA (1); lyn (1); RAMConsult (1)
