Good day to all at CR4
I have a small PV pannel, charge controller and a 300W inverter installed in my house, and feed garden lights (DIY). The problem I have, and which need you all at CR4, is the Inverter. The inverter makes some noise when switched on, which to me, also draws energy, however minimal this may be. My quetsion is:
Q1. Is it possible to disconnect the inverter not to make any sound when switched on? (this inverter also has a battery meter hich I hope not to interfere with as it will let me know when the battery power is low)
I intend to install these lights through a "day-night" switch to ensure they are automatically switched off during the day, further conserving battery power
Q2. If Q1 above is not practical, where can I get a noise-free inverter, possibly up to 1kW (1000W)?
