Previous in Forum: Extruded bars and extruded strips   Next in Forum: CIM in manufacturing
about design of spherical shell pressure vessel
04/21/2007 2:12 AM
sir ,
i want to design a spherical shell with ring type nozzle on top and bottm, (specification: 200 inch inner diameter , finished thickness : 0.450 inch,internal pressure: 43.512 psig,internal temperature : 850F,external condition is atmospheric i.e. ext. pressure is 15 psig, ext. temperature:200F) through pivilite, isit possilbe that it is under safe limit,
Re: about design of spherical shell pressure vessel
04/22/2007 1:00 AM
Even with 0.1%C mild steel-you have 300% margin to Yield Point.
04/22/2007 7:10 AM
Dear
I'm interesting in design & fabrication of pressure vessels 30 years ago in accordance with ASME Code, Sect. VIII, Div. 1, and we hold certificates of authorization U & R.
So you are requested to specify:
1. The sphere material in according to ASME or ASTM, to find out its allowable tensile strength.
2. Design pressure used (not operating pressure).
3. Radiography used for weldment : full, spot or none?
4. Corrosion allowance recommended.
5. Fluid inside sphere, flammable and/or toxic or what?
6. Type of operation, or in other meaning : during operation is it possible to be subjected to a vacuum inside the sphere? if not, no need for external pressure calculations.
7. 850F : dO you mean 850 oF or 85 oF ?
200F : dO you mean 200 oF or 20 oF ?
Good Answers: 137
04/23/2007 4:53 AM
Couple of comments - atmospheric pressure is 0 psig, ~ 15 psia.
You don't say what type of steel, but from from some oldish data I have, for 850°F (454°C) something better than carbon steel is needed.
What does "pivilite" mean?
Cheers......Codey
04/23/2007 10:57 PM
I can offer you detect equipment when you finish your design and put into produce.
its also important.
Location: Next to the Prime Merridian (51°29'34.50"N 0°13'32.85"W)
04/24/2007 9:32 AM
Hi guys,
I think wireless power transmission is light years away. And I do not beleive in it until someone proves it in a practically way that it is possible at a relatively efficient level also.
Sure - transceiving is a one example of it - but at what efficiency level and what's the purpose of it:
  1. Is it energy transfer or
  2. Is it information transfer?
Remember, there are no miracles!
Kceum suggested that if you try to utilise the unwanted electromagnetic radiation/s from those Power Companies then they render you as a thief. I'd say they can go n get nikked and to hell with them and their radiation. Sometimes people sue them for high dose of expose to it. Instead, i would place a large inductor under their transmission lines to capture as much of their undesirable radiation energy levels as possible (especially where the cable-sag is the greaties) and make the most of it. It is only 50/60 hertz and we used to capture enough of it over night to trickle charge the aging batteries of our machineries. It did a good job because the tractor pulled up directly under the power line in the fields and the sniffer coil through a rectifier did the job.
If you call it a power theft so be it. For them it'd be better to be quiet then being sued for exposing people to high levels of radiation.
Making mistake is part of learning.
Abdel Halim Galala (1); cnpower (1); Codemaster (1); Isti80 (1); MUKULMAHANT (1)
