Previous in Forum: Aluminum Busbar Support Distances - LV Switchboards   Next in Forum: Variac Testing
11 comments
Standard Source MVA
09/12/2011 7:53 AM
I want to know standard source MVA as per voltage level to be considered during System study if source MVA is not available.
Good Answers: 170
Re: Standard Source MVA
09/12/2011 10:08 AM
Which country you are from?
Good Answers: 445
09/12/2011 10:14 AM
If you have no access to what is at the other end of the transmission line and/or transformer that is feeding your system then the most conservative estimate is to use an infinite bus as the source. An infinite bus provides a constant 1.0 pu (per unit) voltage source through the series impedance of the transmission line and/or transformer, which in turn provides the maximum current that can be delivered to your system. The short answer is to take the reciprocal of the sum of the two above reactances in pu and multiply the result by the base MVA. You can safely ignore the resistances until you are doing a voltage regulation study.
09/13/2011 12:56 AM
Thanks! But i want to know that is there any standard to assume Fault MVA(If it is not available). Say for Each Voltage level Some standard MVA we can assume.
09/13/2011 12:28 AM
Please ask your utility,if they refuse sue them in the court.
pnaban
09/14/2011 2:38 PM
Table II of IEC publication 76-5 for MVA rating as per voltage level. In IEEE standard I have no idea.
09/14/2011 10:29 PM
Would you provide a link to download it?.
pnaban
09/15/2011 12:02 AM
I think you need to buy, We only have hard copy in our company.
09/15/2011 1:52 AM
Can you provide some table or scan copy of the same?? Thanks
09/15/2011 4:15 AM
09/15/2011 5:35 AM
Thank you very much!!
09/15/2011 6:59 AM
If you can get the same but as per american standard kindly share this too. thanks
Register to Reply 11 comments
electricalexpert65 (1); jonald (4); niks_ele (3); pnaban (2); RAMConsult (1)
