Previous in Forum: Why Voltage Becomes Zero During Short Circuit?   Next in Forum: AC Input to Bridge < DC Output! Amazing
8 comments
11kV/433V Transformer
09/14/2011 12:17 AM
I read in some books that the maximum capacity of 11kV/433V Transformer is limited to 2000kVA. Is it like that or not?. If it is like that then what is the reason? Is there any reason related to voltage range? Please help me...........
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: 11kV/433V Transformer
09/14/2011 1:19 AM
If it is so it is rated for optimum in considering economic,protection and many other facts. Can you calculate rated ampere for transformer having more than 2MVA in its low voltage side?
09/14/2011 5:38 AM
Not true.The restriction of maximum capacity of 11 kv/433 V transformer depends upon the available maximum rating of LV side Air Circuit Breakers (ACB).
These days ACBs of ratings as high as 6300 A are available.This can meet the requirement of maximum transformer capacity upto 4.5 MVA.
However, the capacity of the transformer is normally selected depending upon the Maximum demand of the substation at the concerned load center.
Learning is a never-ending process.
Good Answers: 170
09/15/2011 7:12 AM
But then what will be fault current from a 4.5MVA Trabsformer? Can your 6300A ACB break it safely?
09/15/2011 8:12 AM
Certainly.
You may see ABB's catalogue for Emax type low voltage ACB model No.E6H/f ,which indicates the rated ultimate breaking capacity under short circuit (Icu) as 100 kA at all low voltages including 415 volts . Fault current from a 4.5 MVA transformer will be less than the above value.
Good Answers: 181
09/14/2011 5:57 AM
Economics are a ruling factor. As spradhad said ACB's can be rated up to 6300A but then you have the problem of fault currents on the bus bars and all ancillary equipment related to the system. Multiple lower rated units are a more viable (and safer) option.
09/14/2011 3:09 PM
As well as being easier to transport on standard roads which have size, weight and height restrictions.
Good Answers: 15
09/14/2011 8:05 AM
NOT LIKE THAT.
QUESTION NOT APPLICABLE.
WHAT HELP DO YOU NEED?
Good Answers: 15
09/15/2011 7:42 AM
Register to Reply 8 comments
electricalexpert65 (1); hithuanand (1); jack of all trades (1); soebfatehi (2); spradhan (2); TonyS (1)
