Previous in Forum: Robotic Arm- Position & Force   Next in Forum: Rail Clamps
Socket Weld Tee to Socket Weld Reducer?
09/15/2011 5:59 AM
Hi, is it possible to connect socket weld tee to socket welk reducer? I am confused by a drawing..... The branch end of SW Tee (1") is directly connected with 1" SW reducer, is it possible?
Please comment
Good Answers: 61
Re: Socket weld Tee to Socket weld reducer?
09/15/2011 6:54 AM
Yes
Do it once and do it right
09/15/2011 5:38 PM
Do we need s pipe connection between them or they will connect directly? Which part will go into the others recessed area?
Good Answers: 61
09/15/2011 6:05 PM
Sam,
It is apparent from your questions that you may not be a trained and experienced piper. So please let me offer some help. I also want to apologize for my first short answer. It was obviously not enough for your needs.
I have included the links to graphic and dimensional information on the TEEs and the Swages.
The TEE has a "Socket" that pipe or Swages slip into. There is no need for any pipe between the TEE fitting and the Swage fitting. This can be understood if you consider the Swage as a short piece pf pipe that changes diameter, from what you have to what you want (size wise).
Socket Weld TEEs
http://www.rjsales.com/products/pressure_fit/sw_tees.html
Swage Nipples
http://www.chemoilproducts.com/pdf/piping%20products/Swage%20Nipples.pdf
Please look at both of these links (print them out) study them and you may be able to understand what you can do.
I also want to invite you to visit the "Training" page of the following web site:
http://www.pipingdesigners.com/Training.htm
Read everything there, including the article on "Fittings"
09/15/2011 6:52 PM
Thanks very much, cleared most of my confusion....
Re: Socket Weld Tee to Socket Weld Reducer?
09/16/2011 11:21 PM
The term I have seen most for this is "socket weld insert", which is basically an unthreaded bushing. The large end (male) inserts directly into the female socket of the tee; the small end (female) receives the smaller pipe.
A related term "fitting reducer" is commonly used for soldered/brazed copper fittings. In contrast, a "reducing coupling" or "bell reducer" receives a pipe on both of its female ends.
PennPiper (2); sam12 (2); Tornado (1)
