Previous in Forum: DC Voltage Levels for Testing MV Cable   Next in Forum: Circuit to Amplify Speaker Sound
2 Pole vs 4 Pole Motor
09/16/2011 2:25 AM
If power is proportional to speed x torque, then a motor with the same power have less torque for a 2 pole motor.It will therefore have less magnetising current, then why does a 2 pole motor have the same FLA has the 4 pole ,actually it has slightly more amps, one will think it will be less.
Re: 2 Pole vs 4 Pole Motor
09/16/2011 6:46 AM
It's running st trice the speed, so the frictional losses, like air resistance to the rotor spinning, will be mre. That costs amps.
09/16/2011 10:45 PM
Can you check from any reputed manufacturer and give the no-load and full-load amps of two motors of same hp/kw but different(2p/4p)number of poles?.
pnaban
Good Answers: 804
09/17/2011 12:40 PM
Magnetizing current is only a small portion of the fixed losses.
Register to Reply 3 comments
JRaef (1); pnaban (1); PWSlack (1)
