Previous in Forum: Convertor Transformer (Dual Secondary)   Next in Forum: Weight-Power Relation?
9 comments
Buchholz Relay
09/19/2011 2:55 AM
what is the main reason behind putting the buchholz relay at some angle(5-7 degree)?
India - Member - New Member
Good Answers: 164
Re: Buchholz Relay
09/19/2011 3:15 AM
Please check this old thread : http://cr4.globalspec.com/thread/55884
Re: Buchholz Relay
09/19/2011 3:23 AM
This sounds like a scheme to ensure that gas or vapor can move uphill, while liquid can drain downhill (countercurrent two-phase flow). This is only a guess; a picture would help. Just what is tilted at 5-7°?
Re: Buchholz Relay
09/19/2011 3:44 AM
Buchholz relay mounting Pipe which is used to connect the transformer tank to Conservator is tilted to 5 to 7 degree.
Re: Buchholz Relay
09/19/2011 3:53 AM
In that case, I stand by the conjecture in post 2.
Good Answers: 164
Re: Buchholz Relay
09/19/2011 5:07 AM
You must be very busy, no time for one mouse click...
Nevertheless, Tornado gave the right answer.
Re: Buchholz Relay
09/19/2011 6:29 AM
I check there but he described about need of angle, but my question is why 5-7 degree why not 10 to 20 or......?
Good Answers: 164
Re: Buchholz Relay
09/19/2011 6:54 AM
Well, your question didn't read that way, sorry.
Good Answers: 181
Re: Buchholz Relay
09/19/2011 8:56 AM
The steeper the angle the more gas bypasses the chamber.
Re: Buchholz Relay
09/19/2011 10:02 PM
If the angle is too small, the liquid won't flow downhill well. If too large, the liquid can form into slugs that block the upward flow of vapor. For the given 5-7°, the liquid flows smoothly along the bottom part of the pipe, while vapor flows openly above the liquid.
Register to Reply 9 comments
Deepak.9 (2); kvsridhar (3); TonyS (1); Tornado (3)
