Previous in Forum: Static Var Compensator Foundation   Next in Forum: Vacuum Through Venturi Operated on Compressed Air
Cleeve Lock Nut
09/25/2011 12:13 PM
While tightening the cleeve lock nut, in bolt half of the thread came out. is it ok or problem with nut?
Re: Cleeve Lock Nut
09/25/2011 3:51 PM
When the thread of a bolt comes off from tightening any kind of a nut, you now have a pin instead of a bolt. Usually this is a problem. Then again if you trying to make a pin, congratulations you succeeded.
