Previous in Forum: Cleeve Lock Nut   Next in Forum: Equal Material for SA517 GR B
Vacuum Through Venturi Operated on Compressed Air
09/26/2011 1:40 AM
Hi,
Please let me know the variation of vacuum generated through venturi with change in temperature of compressed air. Is it quantifiable? If yes, then what is the relation between vacuum generated and temperature of compressed air?
Regards
Good Answers: 88
Re: Vacuum through venturi operated on compressed air
09/26/2011 3:14 AM
Air pressure and nozzle diameter being equal, higher the compressed air temp, due to viscosity difference would give higher air (volume/time) flow => higher linear nozzle air speed, => higher max generated vacuum. But I wouldn't expect linearities at that high speeds. S.M.
Good Answers: 137
09/26/2011 6:53 AM
Not sure what viscosity has to do with it, but you imply higher compressed air temperature gives lower viscosity, hence higher flow. Actually, unlike most liquids, air viscosity increases with increasing temperature, as predicted by kinetic theory. From data I have it varies roughly as T0.72.
I wouldn't expect any change in vacuum with air temperature, air pressure and nozzle diameter being equal. Higher temperature means lower density, hence actual volume flow higher, proportional to 1/√ρ, standard (or mass) flow lower by √ρ. But in producing vacuum the same effect works in reverse, leaving vacuum unchanged. That's my take on it anyway.
Codey
Register to Reply 2 comments
